Old 04-17-2005, 10:00 PM
3000gtgrandi 3000gtgrandi is offline
Send a message via AIM to 3000gtgrandi
setting the timing
on a 2 gen, all you have to do is set the timing marks on the cams and crank, correct? you dont have to use a timing light or anything. let me know if this is correct...
Old 04-18-2005, 01:36 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: setting the timing
well 2nd gen would be same as 1st, and a timing light is for ignition timing w/ is ecu controlled...so you have to align w/e marks you're supposed to align w/ the cams and crank.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 04-18-2005, 04:17 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
You need to align the marks on the crank and cams to set the valve timing. A timing light is to set the ignition timing.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-18-2005, 08:39 AM
so i dont have to do anything with a timing light. i know that the 1st gens. can adjust the timing alittle with the CAS.
Old 04-18-2005, 04:03 PM
You talking about 2 diff types of timing here. The marks are for valve timing, the CAS is for ignition timing, you can also set the ignition timing on a 2nd gen and that requires a timing light.
Old 04-18-2005, 08:03 PM
i dont need to do that though, correct? if i set all the timing marks i should be fine.
Old 04-19-2005, 01:02 AM
if all your talking about replacing the timing belt, then no you dont have to use a timing light.
Old 04-21-2005, 02:20 PM
i replaced the head gaskets as well...
Old 04-21-2005, 04:02 PM
same idea
