Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 04-17-2005, 09:38 PM
Treill6 Treill6 is offline
Send a message via AIM to Treill6 Send a message via Yahoo to Treill6
Drivetrain Strength
I'm fixing up a 66 Malibu that has a saginaw 4 speed, 283,and a 10 bolt with 3.08 gears. I would like to get a motor with around 500hp. I'd like to get 4.56 or 4.11 gears. My dad used to flat shift the saginaw and 10 bolt and it never had any problems. Is it harder to break the rear with lower gears, the tires should spin easier...? Will they be strong enough? A book I have "Chevy Performance" has a guys Nova with a 350, about 600hp, and a 10 bolt with 4.88 gears that runs low 10s. It has a picture of him doing a wheelie leaving the starting line. It also says that if you get elongated studs for your main caps a 2 bolt main can hold 600 hp without any problems. But i'll more than likely get a 4 bolt block anyway...
Thanks
Josh
Old 04-18-2005, 11:09 AM
Re: Drivetrain Strength
Also is there any way to make the 10 bolt stronger?
Old 04-28-2005, 11:35 AM
What....So nobody knows anything about rears?
Old 04-29-2005, 12:42 AM
CRUZN69's Avatar
CRUZN69 CRUZN69 is offline
Send a message via AIM to CRUZN69
Well, you asked general questions and answered them yourself.
Old 04-29-2005, 04:28 PM
mdcamaro mdcamaro is offline
Your 10 bolt will be fine. You can buy better axels, replace all the bearings and seals, install an alumium cover, posi.
http://store.summitracing.com good place to start.
