| Off-Topic Talk about anything other than cars. |
What does it mean to run rich or lean?
Hey what's up everybody! I was wondering if somebody could explain to me what it is to run rich and lean. I've been reading threads where someone would mention it, but don't go into full detail. So I wanted to know what they meant to further my knowledge of dsm turbos!
Re: What does it mean to run rich or lean?
for a motor to run correctly it has to have the correct air/fuel ratio so combustion can be present in the cylinders and the motor runs. running lean means that there is more air than fuel. not a good thing, leanness can lead to detonation. running rich is exactly the opposite, you have more fuel than air. this isn't as bad for your motor than running lean but it's still not good. the motor will run to a certain extent with a lean/rich condition, but it won't run very well or won't last as long.
just a quick explanation. you probably could research more on the internet and get a more in-depth version. |
Re: Re: What does it mean to run rich or lean?
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
well yes...that's what i meant, i was trying to put it as simple as i could though, my mistake.
Just to site a quick example for when people refer to air/fuel ratio as x:x, or 11:1 as a sample. That means there is 11 molecules of air (im not sure it's measured in molecules, per say, but you get the idea) to every 1 molecule of fuel. So if the desired air/fuel ratio is 11:1 and you're running 10:1, then you're running richer because there is one less molecule of air per molecule of fuel. Vice versa -running lean, running a 12:1 air/fuel ratio would mean that there is one more molecule of air to each molecule of fuel.
As a reference, on 4g63T's, around 11:1 is considered a good air/fuel ratio on pump gas. On higher octane race gas (117) you're allowed to run a little leaner, like in the ballpark of 12.5:1.
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
The 11:1 is just a ratio. Parts of air : Parts of fuel. It is one of those unitless numbers. The units could be soda can (volume), lbs, grams, liters, etc.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: Re: Re: What does it mean to run rich or lean?
It seems to me that it would have to be some kind of unit. It doesn't make sense that the entire automotive community would refer to something so incredibly important like that and there not be a unit of measurement for it. Maybe I'm missing something, but it just seems like there should be some kind of unit for it.
No, a ratio should be unitless because it's unchanged no matter what unit you're going to use.
If you have 11:1 air/fuel in liters, and 11:1 air/fuel in molecules.. no difference. Still 11 parts air, 1 part fuel. |
Thanks guys.
Ah, I get it now. I'm just so used to everything having certain units with cars that I forgot basic math rules
It is a mass ratio. Its important to mention this, because if it was a volume ratio (for example), it would be very different. We typically look at pounds per minute for airflow, so we tend to covert fuel flow to the same. For example, at 50 lbs/min, and a 10:1 ratio, you would need 5 lbs/min of fuel. Etc. This is the basis of all the calculations in the spreadsheet I set up, and the program wagon put together.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
