Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-17-2005, 06:48 PM
Ceasars Chariot Ceasars Chariot is offline
proper tire pressure for 87 honda civic si ( 175/70/13)
im having no luck finding out what the proper tire pressure is for this car. Since its a JDM verison i cant make out the door code. can someone look and find out what psi im suppose to have the tires?
thanks
c
Car: 1987 Honda Civic SI
Old 04-17-2005, 10:07 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: proper tire pressure for 87 honda civic si ( 175/70/13)
35 psi. JDM, USDM, EDM. tires are tyres psi is no different. should also say on the tires themselves what recommended psi to use, the tires on the car now aren't the ones from the factory
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 04-17-2005, 10:13 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
The recommended PSI should also be printed on the tire.
Old 04-17-2005, 10:16 PM
cvcc_wagon's Avatar
Re: Re: proper tire pressure for 87 honda civic si ( 175/70/13)
got in before the edit
Old 04-17-2005, 10:26 PM
lxndr's Avatar
AF -Advisor
HA!
Too fast for you!
Old 04-18-2005, 01:07 AM
no luck on the tires, the car has 3 kelly 70's and some tire made in Czechslovakia , the Czech tire has a max psi rating of 36 and the kelly tires have nothing.
these tires were on the car when i bought it, so im going to drive on them as long as they last.
im going to drive down to the gas station and pump them up 35 psi each and see how she rolls. thanks guys
c
maybe i can save some gas money too using the proper inflation. will see
Old 04-18-2005, 01:28 PM
lxndr's Avatar
AF -Advisor
35 PSI should be fine, and I'm sure you'll save on gas. I once had a Jetta that I was using to travel between Portland and Seattle on a regular basis. I noticed that my gas mileage started to drop off drastically, so I checked the tires and they were at an average of 25 PSI, filled 'em up and got great mileage afterwards.
Old 04-18-2005, 03:42 PM
lxndr that was a good move, i ended up putting 33 psi all the way around, but each tire was off from 22- 28 psi. you couldnt tell by looking but now im all set !!
Old 04-18-2005, 04:34 PM
lxndr's Avatar
AF -Advisor
Got any pics?
We love pictures!
Especially if you have pictures of yourself dressed up as an intersection bum racing a chariot!
Old 04-18-2005, 07:47 PM
hey man maybe some bad news today not sure, what do you guys think ?
Just doing some routine maintance (rotating the tires) and happened to look up under the car at the transmission. (See Photos) Im not to experienced in auto mechanics so any thoughts on what i need to do would be appreciated. What appears to be going on and what steps should I take regarding this?
Notes: When driving I dont notice anything out of the normal when shifting. Under the car fluid is fresh, and im not sure how long this has been going on.
PHOTO LINKS - CLICK to VIEW
http://uploadhut.com/view.php/72657.jpg
http://uploadhut.com/view.php/72660.jpg
http://uploadhut.com/view.php/72662.jpg
http://uploadhut.com/view.php/72663.jpg
http://uploadhut.com/view.php/72664.jpg
-- Car Specifics:
Year: 1987
Type: Honda Civic SI
Transmission: Manual
Engine Code: EW3
Engine: D15A3
Liter: 1.5
Valve: 12
97 Nissan Maxima (NA with USIM) - [email protected] mph
97 Nissan Pulsar SRV VZR (stock) - [email protected] mph
Old 04-19-2005, 01:56 PM
lxndr's Avatar
AF -Advisor
The first thing I would do is spray some engine degreaser on the motor and bottom side of the tranny. Once everything is relatively clean it will be much easier to locate the leak. It's probably the tranny seal, but you've got oil all over the place under there so it could possibly be a CV shaft seal or the oil pan gasket.
How are your oil levels?
Unfortunately there is no real way to check the tranny fluid level. About all you can do is remove the filler bolt on top of the tranny and fill it up with motor oil until it just starts to pour out of the bolt hole (assuming it's a manual trans).
If it is leaking from the tranny seal there's only one correct way to fix it, tear it apart. You could try to "ghetto fix it" by draining the tranny and cleaning everything up, then squeeze some RTV into the leaky gasket (a friend of mine was in a pinch and did this with super glue, and it worked!)
