Old 04-17-2005, 03:52 PM
N2OZeBozz's Avatar
N2OZeBozz N2OZeBozz is offline
Banned
Send a message via MSN to N2OZeBozz
Talking Rx7....
Original,
Chop,
It didn't come out clean, but.....
I'm pretty satisfied with the homemade headlights and carbon fibre.
Your comments and critics please! It helps!
Old 04-17-2005, 09:20 PM
83scottsdaleowner's Avatar
83scottsdaleowner 83scottsdaleowner is offline
Send a message via MSN to 83scottsdaleowner
it looks pretty good to me, the spoiler is a little off, but other then that its nice -- good chop
Old 04-17-2005, 09:55 PM
hockeygod2787's Avatar
hockeygod2787 hockeygod2787 is offline
Banned
Send a message via MSN to hockeygod2787
Re: Rx7....
^ my words exactly!........... good work
Old 04-17-2005, 10:45 PM
-GS-'s Avatar
-GS- -GS- is offline
Send a message via AIM to -GS-
Re: Rx7....
Looks great. But as a future suggestion, try to either save your work at a much higher quality, or try not to use red when saving at low quality, because red allways comes out the worst at low quality.
Real Name: Gurpreet
Old 04-18-2005, 06:53 AM
N2OZeBozz's Avatar
Banned
Re: Rx7....
Thanks guys
Old 04-19-2005, 09:09 PM
Legionofone's Avatar
Legionofone Legionofone is offline
Re: Rx7....
whats ur CF technique?
Old 04-20-2005, 07:00 AM
N2OZeBozz's Avatar
Banned
Re: Rx7....
2. Create a new document, size = 2 pixels wide 1 pixel deep.
press Ctrl + 0 to zoom in to the correct size.
3. Grab the gradient tool and fill from left to right.
4. go to Edit+define pattern, save as carbon fiber.
5. select the "carbonised" area with the lasso tool.
6. Go to edit + fill... select carbon pattern and opacity= 75%
option= darken. desaturate by pressing Ctrl+Shift+U then go to image + adjustments + brightness/contrast.
7. darkeness to -50 then filter + blur + motion blur.
set the percent to 1 pixel.
6. fill the area again with the pattern as before but set the opacity to 50%
This was posted by NICECAR. But made a few variations in it. This would be my step 5,
1/You select the area to be carbonised,
2/Press ctrl+shift+u to desaturate it
3/click image>adjustment>brightness/contrast. Adjust the setting to your needs
4/Press ctrl+j to make to copy layer
5/hold ctrl and click on the new layer to select it
6/Then go layer>new fill layer>pattern and click ok in both windows...you can vary the size of the pattern before clicking ok if you want, but didn't do anything on the RX7
7/then go layer>rasterize>layer
8/go, Filter>distort>twirl
decrease the image size by the zoom slider
right hand click on the image and click on free transform
9/Edit the image until it covers the full area to be carbonized
10/Click on the layer you created
11/Press ctrl+shift+i to get the inverse of your selection
12/press delete, to erase all excess carbon fibre
13/Adjust your opacity
14/Merge down the layers afterwards
thats it, its mixture of my technique and that of nicecar. It may not be the best technique.
You can find more on
http://photochop.net/tutorials.html
digimods.co.uk
Hope this helped!
