Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 04-17-2005, 12:29 PM
nsbs nsbs is offline
Question AirBAg Light
I have an 2002 Jetta TDI, standard transmission, 90,000km
Air bag light came on when ready to start, will not go out when started or with the key in the on position.
My warranty has expired, so wondering if there is anything I can check or do.
Thanks
Old 04-18-2005, 08:38 AM
Does anyone know if it's possible to clear codes without the "VAG COM"
I'm hoping this might get rid of the always on Air Bag light.
Thanks
Old 04-20-2005, 11:04 AM
boschmann boschmann is offline
Re: AirBAg Light
You need a scanner to access the system.
Old 04-20-2005, 08:48 PM
Re: Re: AirBAg Light
Thanks Boschmann, I ordered the cable for my laptop and found some shareware for the Vag Com, hopefully I can sort this out.
Old 04-21-2005, 08:33 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I dont belive the VAG-COM can access the airbag system because of safety concerns. Check there website www.vag-com.com i believe.
Old 04-21-2005, 08:53 PM
Re: AirBAg Light
I have a share ware version of the Vag Com
After installing on laptop and then plugging into the diagnostic plug, here is what I get
18044- I'm assuming this is the code
Powertrain Data Bus Missing Message from Air Bag Controller.
P1636-35-00 No Idea what these numbers represent
038 906 012 FD Controller Part # ?
In another box I get "No response from controller".
Any thoughts or ideas anyone?
Thanks
Old 04-23-2005, 02:07 PM
Re: AirBAg Light
The concern with the VAG-COM & air bag controllers is on the '00-'01 models with specific part number (6Q0-909-605-A) & supposedly it does the same thing when VW uses their 1551/2 scanner.
http://www.ross-tech.com/vag-com/vw_issues.html
I beleive you need to register the shareware ($99) to be able to get into the air bag controller to get the real trouble code for the air bag system, what you have in that ECM P-code is just that the engine controller knows the air bag system is offline.
Old 04-24-2005, 10:14 AM
Thanks boschmann, off to VW dealer in the morning.
