Old 04-17-2005, 01:33 AM
The Black Pearl's Avatar
The Black Pearl The Black Pearl is offline
K&N Filters
If you have or used a K&N filter for your TB did it make a difference or cause problems?
Check out my GM experience
http://www.automotiveforums.com/vbul...d.php?t=389060
2005 Red Santa's Sleigh c/w Toyz (MINE)
2004 Black Chevrolet Extended Trailblazer (ALL MINE)
2002 Silver Mazda Protegé GT (Hers)
Old 04-17-2005, 04:22 AM
ScarabEpic22 ScarabEpic22 is offline
as of this very moment, a K&N Filter is the only intake mod I have done, and wow, was it worth the price. My gas milage is running right around 19.5mpg about 75% hwy and 25% non highway. Acceleration is also much smoother, just stomp and go! I have been running one since 12/28/04 and instantly noticed the improved milage while going on a trip. Hope this helps, Erik
Old 04-17-2005, 04:23 AM
I almost forgot, I haven't had any problems so far, but it is mainly my trip car, so I have only put about 1000-1500 miles on it since December. Erik
Old 04-17-2005, 12:05 PM
dach95 dach95 is offline
Re: K&N Filters
I still want to keep the resonator, so I'm considering changing just the air filter to KN E-1009. Has anyone done this and what is your experience?
Old 04-17-2005, 02:32 PM
This is exactly what I have done, just replace the air filter element with K&N part #E-1009. I didn't want to purchase the whole intake and I don't think I will at this point. The filter alone is good enough for me. Check http://www.ajusa.com for the filter and cleaning kit. The auto stores around here, NAPA and Schucks wanted $95-100 fo it, and ajusa had it for around $53. Hope this helps, Erik
Old 04-18-2005, 12:31 PM
Re: K&N Filters
Thanks, I think I'm going to give it a try.
Old 04-20-2005, 07:00 PM
Installed one tonight, noticed a difference in accelerating a bit also a different sound not loud, but different.
Old 04-24-2005, 06:50 PM
anon anon is offline
Re: K&N Filters
I installed the 77 pro series kit on my 4.2 tb today. It seemed to give it a little more pep. Not WHOA, but helped. I am hoping the gas mileage increase is true since that is mainly what I bought it for. I also wanted a little more tourqe when going up hills (kinda felt dead until it kicked into a lower gear), which from the 3 trips I have gone on so far seemed to help. My instant fuel economy indicator on the driver info center said 0 the first trip, the second trip it started giving me info again, other than that no problems.
Old 05-02-2005, 06:00 PM
Re: K&N Filters
I've just installed the KN1009 and found that it does make a slight improvement in acceleration. Too early to tell if it helps mpg yet. But I'm happy for the moment...
Old 05-06-2005, 09:30 AM
herkyhawki herkyhawki is offline
Re: K&N Filters
It's definitly not worth doing this mod. You are giving GM a perfect excuse to Not cover a large number of warranty items from emission sensors to the entire transmission. The oil used on the filter is very bad for the sensors. see GM TSB in the Link.
http://www.automotiveforums.com/vbul...d.php?t=401233
Old 05-06-2005, 07:19 PM
99markss 99markss is offline
Concerning that GM TSB.......... it says look for an excessively oiled filter. I can see if the filter was dripping the oil when you installed it, but other than that I have used K&N filters on all my cars since 1987 and have never had a problem. They dont need much oil for coverage. I oil mine and let it sit upright over nite, it will drain any excess and keep what it needs. Also in the case of my 2003 TB 4.2, where is the MAF? If it has one it is hidden. So what is GMs excuse now? I would be more concerned with the oil vapor after shutdown coating the MAF than filter oil, its the oil vapor that clogs the idle air control valve and throttle body blade in every fuel injected car/truck that GM makes.
Old 05-07-2005, 11:37 PM
Re: K&N Filters
I wouldn't say don't go for the KN's. They are good, just beware that excess oil can do harm. Which I plan to clean and let it sit at least 48 hours for the excess oil to drain. Meantime, I'll stikc back the paper one.
As mentioned before, I'm still happy with the better accerlation and a slight improvement in my Mpg.
Old 08-23-2005, 11:13 PM
lstlap lstlap is offline
Re: Re: K&N Filters
Well, I know that this is an old post, but I was wondering if anyone experienced the same thing. I have a 2004 TB 4.2 5 passenger and dropped in just the replacement K&N air filter. I have run both FIPK and replacement drop in's on several vehicles without a problem and was always pleased with the results. Well, i put the one in my TB at about 5K miles and as soon as it hit 8K miles some strange things started happening. I got an SES light that just wouldn't go out, a lumpy idle when the engine is cold, and when cruising and holding steady on the gas pedal, it will buck ever so slightly but just enough that I could feel it. The K&N filter was factory oiled with no excess oil that was apparent, and a check of the intake hose and sensor by the throttle body showed no oil residue at all. Dropped the stock filter back in and drove it down the block. Within 1/4 mile, the SES light went out (first time in a week) and none of the bucking or lumpiness was evident. Off to the dealer tomorrow morning to have it checked out, just in case. Anyone know if the trouble codes that switched the SES light will still be in there?
2004 TB LS 4WD
Old 08-23-2005, 11:29 PM
2004 TB LS 4WD
Old 08-24-2005, 01:37 AM
Stan172 Stan172 is offline
Why not just take the air cleaner out??
read this:
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
