Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-16-2005, 07:45 PM
Cat Fuzz Cat Fuzz is offline
Electric fan not working.
I've tried searching but couldn't find any info.
The electric fan on my 94 3.2L is not working. It will work if I apply power directly. I understand there is a relay somewhere but I can't find it. Chasing wires is problematic since they disappear into large wrapped bundles. Can anyone tell me where to look for the relay? It's not in the engine bay fuse/relay box and I can't find any other relays under the hood.
Old 04-16-2005, 08:01 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Have you checked the resistor block?
2000 VW New Beetle TDI
2007 Honda CR-V
Old 04-16-2005, 10:20 PM
Resistor block? Is it that little square thing right next to the fan? I thought that was a noise suppresor.
Old 04-18-2005, 12:16 AM
No one else has any info on this problem? I found an old thread about it but there wasn't a solution posted.
Old 04-21-2005, 04:33 PM
Re: Electric fan not working.
Sorry to not have responded sooner. To answer your question, I'm not exactly sure where the resistor block is located but according to the fan schematic, electrically it is between the switch and the fan. It contains three resistors (which determine fan speed) and a fuse. Seeing as you've determined that the motor works (I saw your post on 4x4 wire), I would try and find the resistor block.
2007 Honda CR-V
Old 04-21-2005, 08:53 PM
Re: Re: Electric fan not working.
No,no,no. I'm talking about the electric radiator fan, not the heater blower motor.
Old 04-21-2005, 10:02 PM
Re: Re: Re: Electric fan not working.
Oops, my bad. Sorry.
2007 Honda CR-V
Old 06-23-2005, 12:12 PM
rprinz rprinz is offline
I have the exact same problem with my 96 Rodeo. I have yet to remedy the problem for the same reasons that you have already stated. Any help here would be appreciated. I'll let you know if I find something.
Old 06-23-2005, 05:38 PM
I was just a little bit low on coolant. Added about a half gallon and everything is good.
Go figger.
Old 06-23-2005, 06:09 PM
Go figger.
Hmm, so you added coolant and the fan started working again? Perhaps there is a sensor in the radiator (which I could not find) and there must be enough coolant in order to reach it?
Mine was also a half gallon low, but the fan still doesn't seem to be working after topping it off. I'm guessing that maybe it is the sensor. Now I just have to find it and test it.
Thanks for your prompt reply.
