OBD II error code P1415
I have a 2001 Yukon, and the service engine soon light came on although the engine seems to run fine. I used a scanner and it showed one code: P1415. At http://autorepair.about.com/cs/troub.../bl_obd_14.htm
it is listed as: P1415 Secondary Air Injection (AIR) System Bank 1 (GM) Can someone tell me what this means and what I shoud do about it? Thanks |
Re: OBD II error code P1415
Hi, hope this helps. Might be oxygen sensor. Short answer: Scan tool = Tech II computer = Dealer.
6-2506 Engine Controls - 4.8L, 5.3L, and 6.0L Engine DTC P1415 or P1416 Circuit Description A secondary air injection (AIR) pump is used on this vehicle to lower tail pipe emissions on start-up. The powertrain control module (PCM) supplies a ground to the AIR pump relay, which energizes the AIR pump and the AIR solenoid valve. Engine vacuum is applied to the AIR shut-off valve when the AIR solenoid is energized. The engine vacuum opens the AIR shut-off valve which allows air to flow to the exhaust manifolds. The PCM monitors the heated oxygen sensor (H02S) voltages to diagnose the AIR system. During the AIR test, the PCM activates the AIR pump during Closed Loop operation. When the AIR system is activated, the PCM monitors the H02S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the H02S voltages should go low and the short term fuel trim should go high. If the PCM determines that the H02S voltages for both banks did not respond as expected during the tests, the diagnostic trouble code (DTC) P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative. Conditions for Running the DTC • DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0111, P0112, P0113, P0116, P0117, P0118, P0121, P0122, P0123, P0131, P0132, P0133, P0134, P0135, P0137, P0138, P0140, P0141, P0151, P0152, P0153, P0154, P0155, P0157, P0158, P0161, P0170, P0171, P0172, P0173, P0174, P0175, P0200, P0300, P0335, P0336, P0351, P0352, P0353, P0354, P0355, P0356, P0357, P0358, P0440, P0442, P0446, P0506, P0507, P1133, P1134, or P1258 are not set. • The startup engine coolant temperature (ECT) is less than 70°C (158°F). • The engine run time is more than 2 seconds. • The manifold absolute pressure (MAP) sensor is more than 75 kPa. • The engine load is less than 40 percent. • The engine air flow is less than 20 grams per second. • Engine speed is more than 900 RPM. • The vehicle speed is more than 15 km/h (25 mph). • The ignition voltage is more than 11.7 volts. • The air fuel ratio is 13.125:1. • The ECT is between 70-110°C (158-230°F). • The intake air temperature (IAT) is more than 2-100°C (36-212°F). • The fuel system is not operating in power enrichment or deceleration fuel cut-off (DFCO). • The short term fuel trim is in cells 5 or 6. Conditions for Setting the DTC • The H02S voltage does not go below 222 mV for 1.2 seconds or more. • Short term fuel trim does not go above a predetermined amount. Action Taken When the DTC Sets • The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails. • The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records. Conditions for Clearing the MIL/DTC • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail. • A current DTC, Last Test Failed, clears when the diagnostic runs and passes. • A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic. • Use a scan tool in order to clear the MIL and the DTC. Diagnostic Aids Important: Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing or replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent water intrusion into the PCM. • Casting flash in the exhaust manifold may restrict the amount of air flow necessary to affect the H02S voltage. If you suspect this, remove the air pipe from the manifold and inspect the passage. • Using the Freeze Frame/Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame/Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same Freeze Frame conditions such as RPM, load, vehicle speed, temperature etc. that you observed. This will isolate when the DTC failed. • For an intermittent condition, refer to Symptoms • Engine Controls. Test Description The number below refers to the step number on the diagnostic table. 3. A check valve that flows in both directions causes heat damage to the AIR system components. Engine Engine Controls - 4.8L, 5.3L, and 6.0L 6-2507 DTCP1415 or P1416 Action Values Yes No Schematic Reference: Engine Controls Schematics Step: 1 Action: Did you perform the Diagnostic System Check-Engine Controls? Value: — Yes: Goto Step 2 No: Go to Diagnostic System Check -Engine Controls Step: 2 Action: Important: Before proceeding with this diagnostic table ensure that the AIR pump is operating and that air is present at the outlet of the AIR shut-off valve. If the AIR pump is inoperative and no air is present at the outlet of the AIR shut off valve, refer to DTC P0410 for further diagnosis. 1. Install a scan tool. 2. Idle the engine in Closed Loop. 3. Turn OFF all the accessories. 4. Monitor the bank 1 sensor 1 left front H02S voltage display on the Engine 1 Data List using a scan tool. 5. Enable the AIR pump using a scan tool. 6. Observe and record the Bank 1 Sensor 1 (Left Front) H02S voltage, as the AIR pump is enabled. Does the H02S voltage drop below the specified value? Value: 350 mV Yes: Goto Diagnostic Aids No: Go to Step 3 Step: 3 Action: Visually and physically inspect all hoses and pipes for: • Being connected • Clamps are secure on pipes and hoses • No kinks, holes, or pinched hoses and pipes • Components with evidence of heat damage Are all of the above OK? Value: — Yes: Go to Step 4 No: Go to Step 6 Step: 4 Action: 1. Disconnect the hose from the check valve at the left exhaust manifold. 2. Enable the AIR pump using a scan tool. Is air present at the hose outlet? Value: — Yes: Go to Step 7 No: Go to Step 5 Step: 5 Action: Repair the restriction or blockage in AIR hoses/pipes between the left exhaust manifold and the point where the systemrfiranches to both sides of the engine. Is the action complete? Value: — Yes: Go to Step 8 No: — Step: 6 Action: Repair the condition found. Is the action complete? Value: — Yes: Go to Step 8 No: — Step: 7 Action: Replace the check valve. Refer to Secondary Air Injection (AIR) Check Valve/Pipe Replacement -Bank 1. Is the action complete? Value: — Yes: Go to Step 8 No: — Step: 8 Action: 1. Use the scan tool in order to clear the DTCs. 2. Turn OFF the ignition for 30 seconds. 3. Start the engine. 4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text. Does the DTC run and pass? Value: — Yes: Go to Step 9 No: Go to Step 2 Step: 9 Action: With a scan tool, observe the stored information, Capture Info. Does the scan tool display any DTCs that you have not diagnosed? Value: — Yes: Go to Diagnostic Trouble Code (DTC) List No: System OK Take care, Eggert
Thanks for the very complete answer! I erased the error code and so far it hasn’t come back. If it does, it looks like I can at least go through some of the steps without the Tech II tool, and see if I find the problem, before taking it to the dealer. Thanks again!
I replaced both LEFT & RIGHT black air gizzmos..cost me $32.00 ea. and had to be purchased from dealer....I was told this is common problem...the only problem I ran into is that the hose clamp coming off one side of rubber hose takes a special tool to get off...or a lot of dexterity. The modules are black, connecting to black rubber hose on one side and threaded on other side, with a larger round center...approx. length of 3" with dia. of 2" located coming off of exhaust manifold both on left and right sides of motor... connecting eventually to a canister on the passenger side against firewall under the hood. Hope this helps you...cost me a trip to GOODGUYS (DORKGUYS) on a weekend...gave me code and mumble jumble answer and told me to come back when their "master tech" was onhand to find problem....I asked the dork who had no idea where to look if maybe it was under the drivers side...he looked their....lol... well I too purchased scan tool to reset code and came back...I have replaced both modules and have had NO PROBLEMS nor reoccurring problem for 2 months now... good luck JC Last edited by kevlar7; 04-30-2005 at 01:17 AM. |
