Old 04-16-2005, 07:33 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Oil Leak and white smoke
Ok I was looking through my old threads and since i saw blue smoke at startup tonight figure i put it in here instead of starting a new one. From searching i think it is oil getting into the combustion chamber.
But for the above on cold days it billows like a chimney and warm days does it right when you start up and it will completely cover the entire vehicle.
Now when i start it i found out tonight it is blue. I have been having an oil leak for about a month. Right after the oil cooler hoses were replaced it started. Checked all those nuts and bolts first all tight. Secondly installed Fram Sd-1 and think that could be problem because it does not cover the opening completely. When it is put in and tightened the best i can get itto fit is covering the whole top area of the drain hole and the gasket covering the bottom part. I still have the old drain plug and am going to Autozone tomorrow to get a gasket for it.
Could this be leaking because i recently decided to go to 5w-30 instead of 10w-30? I read through some threads that stated that on older rigs the seals just can not handle that type oil in there old age.
To replace the white smoke i have decided that when i get the money together to do the valve seals. My mechanic gave me a quote of 140 for parts and labor.
Any suggestions or ideas on the leak stop would be cool. I am thinking of picking up a case of Quaker State 10w-30 High Mileage because i have the 5w-30 in there now.
I dont know if it matters but i ran a can of Gunk through at the beginning of March.
Tried to post in old thread could not. Here is the link to it to refresh our memories
http://www.automotiveforums.com/vbul...ght=blue+smoke
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 04-16-2005, 09:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Oil Leak and white smoke
valve seals.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-17-2005, 10:40 AM
yeh i figured that they were probally gone.
What about the leak do you think the 5 weight oil is causing the problem or no.
Old 04-17-2005, 11:22 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Oil Leak and white smoke
The 5 in 5w30 has nothing to do with weight.
It is a cold flow factor.
It is probably thinner than a 10w30 at room temperature.
This is not an oil problem, this is a valve seal problem.
Oil will not cure this, you need to fix the cause of the leak, not what leaks through them.
Old 04-17-2005, 11:55 AM
i understand that but why would a leak be happening at the freaking drain plug
Old 04-17-2005, 12:40 PM
BlazerLT's Avatar
AF -Advisor
You need a new oil drain plug gasket.
Old 04-17-2005, 01:25 PM
It is a new plug and gasket
Old 04-17-2005, 10:51 PM
BlazerLT's Avatar
AF -Advisor
And it is still leaking from it?
You sure the oil is running down from above?
Old 04-18-2005, 06:10 AM
Its not i washed it at the car wash with engine cleaner then i sprayed engine degreaser under there let it sit and it seeps out from there .
Old 04-18-2005, 06:46 AM
blazer94's Avatar
blazer94 blazer94 is offline
The threads could be stripped out a little. This happened to me, even with a new plug and gasket. I had to tap the old threads (very careful there) and than drained the oil and put in fresh just in case I got any metal debris in the pan. Problem was corrected. My oil plug was 5/8. To find out, try a wrap of teflon tape and check the plug again. This is how I discovered mine.
Trailblazer 2005.
2WD LS
Brand new, No Mods Yet!
Old 04-18-2005, 01:30 PM
Im gonna try again thursday or wednesday i am gonna do the front brakes one of those days so it will be whatever day i dont do them. Will let everyone know.
Old 04-18-2005, 06:54 PM
BlazerLT's Avatar
AF -Advisor
I'm thinking the the wrong gasket was used or the threads are cross threaded.
Old 04-18-2005, 08:05 PM
Will check back wednesday
Old 04-25-2005, 06:11 PM
ok i found the problem tonight
I took fram out and ran my finger around inside and found about half of my thread was broke off inside.So i got old plug put back in with the gasket from the new plug and finger tightened it since it seemed to be spinning after it got so tight.
Old 04-25-2005, 06:14 PM
BlazerLT's Avatar
AF -Advisor
Did you get the thread back out of the oil pan?
