Old 04-16-2005, 06:07 PM
acoustic-sounds acoustic-sounds is offline
420a Motor, OIL IN AIR INTAKE
What would be the cuase to have oil in my air air intake tubing and TB. Could a bad head gasket cuase this or would it be a bad head or some-thing worse. Let me know as im doing a complete head gasket change and dont want to have the same prob after I start up, after work is done.
Also theres oil seaping out the back of the motor only after redlining at 7000rpm in each gear. Not sure where its comming from.
Old 04-16-2005, 06:31 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: 420a Motor, OIL IN AIR INTAKE
I assume on the 420A as with turbo cars, there are vacuum lines going to the intake that put a little oil in there.
Old 04-16-2005, 06:43 PM
Re: Re: 420a Motor, OIL IN AIR INTAKE
[quote=JoeWagon]I assume on the 420A as with turbo cars, there are vacuum lines going to the intake that put a little oil in there.
Theres more then a little in there, Maybe a cap full of oil.
Old 04-16-2005, 06:49 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
replace the pcv valve. it's the little 90 degree elbow between the intake manifold and the valve cover.
95 Talon TSI AWD
97 Eclipse GST
Old 04-16-2005, 07:46 PM
Thanks, Ill replace the pcv valve, I about time to do so any-ways.
Old 04-16-2005, 07:57 PM
Re: Re: Re: 420a Motor, OIL IN AIR INTAKE
What about oil seaping of the engine. (Oil is all over the place after driving it) not sure how much but enough to make a mess out of my engine compartment.
Old 04-17-2005, 01:58 PM
96probegt's Avatar
96probegt 96probegt is offline
sounds like broken piston rings my buddys prelude was doing the same thing we tore the engine down and two of his rings on his #4 piston were gone
Old 04-17-2005, 05:12 PM
if it's making a mess in the engine compartment and on the exterior of the engine, it could be a number of things. try to pinpoint or give a specific area/region where it's coming from (back, front, top, bottom, exhaust mani, etc) and it would be easier to give help.
95 Talon TSI AWD
97 Eclipse GST
Old 04-17-2005, 07:10 PM
coolguycooz coolguycooz is offline
it could be the head gasket looking at the engine from the front the 420a's as in the neons also had a weak spot there and lots of oil would come out if its in the top right corner area then its your head gasket buy a new one from mitsu the ones they sell now have that corner thicker or something.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 04-17-2005, 09:45 PM
pr0's Avatar
pr0 pr0 is offline
Could be valve guides if not your rings or pcv valve.
Pete (RS_T atx)
Old 04-17-2005, 10:28 PM
could be a valve cover gasket too, it could be lots of things.
95 Talon TSI AWD
97 Eclipse GST
