Old 04-16-2005, 03:50 PM
airtight_python airtight_python is offline
Question Slipping Transmission?
I am just wondering what exactly happens when your transmission slips. I'm trying to differentiate between that and an ignition problem. If accelerating hard at low speeds sometimes the truck will start to "buck like a bronco." It does the same at high speeds but not as drastically. I can't tell if it's a missfire or what?
Old 04-16-2005, 03:55 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Slipping Transmission?
When i've had a tranny slip, it was a delay from when I hit the gas until the wheels actually started to turn. It would take just a second for the tranny to catch up and then the truck would take off with a "snap"
Old 04-16-2005, 03:56 PM
Hmm.. that's a good sign. I'm hoping I just need new plugs or somethin. Thanks
Old 04-16-2005, 06:02 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
It almost sounds like a spark problem by the way you describe it , or it could also be a fueling problem. I would personally start with the fuel filter it is the easier of the two jobs, the other being the spark plugs AND wires. That last plug at the firewall on the passenger side is a bitch to get at, at least on the 4.8 it is.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 04-16-2005, 08:31 PM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
go get your codes pulled by a transmission shop, if its the transmission, they usually are pretty good about storing codes when they have a prob...but doesnt always throw a light...good luck
'99 Silverado 4 x 4
bunch of goodies
Old 04-17-2005, 09:42 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Mines done it a few times, but it's been a while since the last time. Whenever mine does it, it usually happens when I get on it and it'll get stuck b/w like 2nd and 3rd and flip back and forth before it makes up its mind.
*Under Construction - New sig to debut*
Old 04-17-2005, 11:50 PM
I'm starting to think (and am pretty sure) it isn't a transmission slip now. I'm leaning toward fuel problem. Maybe even the injectors acting up?
