Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-16-2005, 01:52 PM
SGTKoz SGTKoz is offline
Send a message via Yahoo to SGTKoz
Vibrations at higher speeds.
I have a 98 Dakota 4x4. I get vibrations, mostly felt in the stick, but can be felt in the body when I reach speeds between 50 and 65 mph. The vibrations seem to dissapear beyond 65 mph. Any suggestions as to what this could be?
Old 04-17-2005, 05:21 PM
Skyline_BNR34's Avatar
Skyline_BNR34 Skyline_BNR34 is offline
Registered User
Re: Vibrations at higher speeds.
Ball joints or something. It could also be a lose tranny bolt, best advice have someone look at it and see what they say. Check your lug nuts too, could be a lose wheel.
Old 08-21-2005, 04:28 PM
Mr. Normal Mr. Normal is offline
REPLY to above: A friend of mine just had this problem w/a Ford 150. Turned out to be a problem w/exhaust system loosening up, and the muffler dragging on the drive shaft. It carved a groove in the drive shaft, eventually; throwing it off balance. Had the drive shaft and universal joints, replaced. It seems it might have been bad enough of a shake that he has to have the rear end checked out, now. Might have worn out the gear in the "pumpkin" of the rear axle prematurely.
I, had a similar symptom in a car once. Turned out that I had to have the tires spin balanced ON THE CAR to resolve the problem. Wonder if your problem could be this simple? Is the vehicle aligned, properly?
Old 08-25-2005, 08:15 PM
riverat440 riverat440 is offline
Usually a vibration between 45 and 65 is tire related
Old 08-25-2005, 11:27 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
you mentioned that it was felt mostly in the stick. If you've had a clutch job done, make sure the shifter is bolted tightly to the transmission. Also, make sure your bellhousing bolts and subframe bolts are properly tightened.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
