Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 04-16-2005, 11:36 AM
notamonkey69 notamonkey69 is offline
over heating
Hi Everyone. I have a 97 malibu and a guy at work has 00. We both had cooling problems with fans not coming on. Mine is intermittent and seems to be electrical I might just jumper the fans for the summer months. His turned out to be his reservoir cap. The o-ring was rotten and did not allow pressure to build up. I do not know the circuit path to explain why the fans didn't come on but he had serious problems with over heating and coolant coming out all the time and now he doesn't.
Old 04-18-2005, 04:35 PM
bearcatdon bearcatdon is offline
Re: over heating
Your friend’s problem was that without pressure the antifreeze has a lower boiling point and would cause the engine to overheat and lose the coolant.
Your problem seems to be a temp. sensor. Start your car then turn the A/C on. Did that start the fan? If the fan started, your temp. sensor is defective. This is probably why you think it is intermittent. Don't forget that these engines run hot and the fans don't kick in until the gauge gets to about 3/4.
Old 04-18-2005, 07:53 PM
wymi wymi is offline
Re: Re: over heating
Aren't the fans suppose to come on when the AC is on?
Old 04-19-2005, 11:09 AM
johnholl johnholl is offline
The cooling fans do not come on until this engine get extreemly hot. Too hot in my opinion [250 degrees, I think?]
Old 04-19-2005, 12:22 PM
Re: over heating
My fans come on at 225 degrees if I let them. I put in a toggle switch to send power to the low speed fans when I see the temp needle swing a little bit past half on hot days.
Old 04-19-2005, 04:53 PM
Re: Re: Re: over heating
Yes, the fan will automatically come on when the AC is running regardless of the engine temp. Otherwise, the temp. sensor will turn them on at the 225 range. Therefore, if you start a cold engine, turn your AC on and the fan works, the sensor didn't kick them in when the engine got hot.
