Have a question....Sometimes I'll be driving and all of the sudden when I hit the gas to accelerate nothing happens. The RPMs don't even go up. Sometimes I even lose speed unless I slowly give it gas. I have replaced all plugs/wires, and even the MAF sensor. Could it have anything to do with the throttle? Transmission? Any answers will help.
Is there another site where I can ask a question like this? I'm not being rude I just need help.
Re: Can anyone help?
Hmmm.. Possibly something in the transmission, but have you checked for any codes yet?? How about fuel filter, pug wires hooked up right, coil packs? What year do you have. That may help.
1971 Chevy Monte Carlo ah.. the power of a V8 ![]() 1993 Chevy Blazer: 97k miles, Flowmaster Exhaust, K&N Filter Charged
Its a 94. Plugs/wires are hooked up right. My mechanic hooked it up to a computer and it did give a code. It was 186 INJ pulse width too high or MAF too low. He said the most likely cause was a faulty MAF sensor so he replaced it.
Well thats an awfully expensive part to just replace. Make sure that it is the correct air flow sensor and that it wasn't damaged when it was put in. If you have a star torx screw driver it comes out easily. They have them at auto places and Sears. It looks like a hex head with a hole in the center. I would try a different mechanic. It definately has to do with the way the computer is reading air flow. Hope this helps
Thank you a bunch for your help.
does it do it all the time. have a compitant shop hock up a fuel gauge and see if the fuel pressure is dropping off. it sounds like you are loosing fuel pressure
it doesnt do it all the time but it is low on power all the time.
Re: Re: Can anyone help?
Re: Re: Re: Can anyone help?
Yes it will. If there is no way for air to go out, there is no way for air to go in.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
I'll try that. Thanks alot guys for your help. I really do appreciate it.
same problem with 97 eddie bauer explorer
Did the car get a weird smell in it when it first lost power? Because what you described is almost exactly what happened to mine and I had to replace the cat converter
Wouldn't hurt to check the air filter if you haven't already. Take it right out. I had a squirrel that was hoarding acorns last fall. I cleared about 3 lbs out from under the filter. Easy check.
I checked the air filter and its fine. I don't recall a smell, when it loses power. I took it to a mechanic and he hooked it up again to a CPU and it showed no codes. He suggested replacing the fuel pump.
