Old 04-16-2005, 09:28 AM
mme43 mme43 is offline
Question 1990 s10 dash lights
My 1990 s10 has several dash lights that have either stopped working all together or work intermittently. The left side of the dash is dim, so it leads me to believe a bulb is possibly burnt out. The right blinker light has stopped working altogether, an the high beams light works sometimes, but not always. What can i take apart to get to the dash lighting system, how do I get to the lights? any advice is greatly appreciated, thanks.
Old 04-17-2005, 10:29 AM
STOVE BOLT STOVE BOLT is offline
Re: 1990 s10 dash lights
NOT UNUSUAL. THE DASH CAN BE REMOVED BY TAKING OUT A FEW SCREWS. PULL THE ENTIRE ASSEMBLY OUT STRAIGHT. THERE IS A ROW OF PINS ON THE BOTTOM OF THE PANEL THAT JUST PLUG INTO THE ELECTRICAL SYSTEM, THAT MUST BE PULLED OUT AS YOU REMOVE THE PANEL. YOU`LL SEE WHAT I MEAN WHEN YOU GET IN THERE. IT IS NOT A HARD JOB AT ALL. THE BULBS SIMPLY TWIST LOCK INTO THE BACK OF THE DASH PANEL ASSEMBLY. I HAVE DONE SEVERAL OF THESE AND HAD EXCELLANT RESULTS. JUST BE CAREFUL, AND USE YOUR COMMON SENCE.
GOOD LUCK .
STOVE BOLT
