My car died out on me the other day.
i ran some test and im gettin no spark and smell no gas anywhere, which mean no fuel either. anyone know what could have caused this |
Re: Car Died
you could have a bad ASD (Automatic ShutDown) relay. If the relay's ok, then something else tripped the relay.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
My crank and cam sensors where bad so i replaced them, and now im getting a code 42 stating that something is wrong with the autoshutdown relay.
Re: Car Died
switch out your ASD relay and see what goes, could be a bad relay.
i tested the relay and the thing is GOOD. i was told by a shop it could be my timing belt. TRUE?
Re: Car Died
NO...the timing belt will not cause that code. It could be wiring with the relay and not the relay itself. Have you clear the codes and see if they come back.
i cant e ven get tthe car out of my drive way so i cant clear the codes.
a shop is comming to pick the car up friday. ive had enough |
Re: Car Died
I hear ya. They can be tough theses days. I thought that if you had the ablilty to read codes then you would be able to erase the codes. I don't what you are using to read the codes. With my machine I can read and erase and view data stream.
Re: Car Died
did you get your car fixed and what was the problem my car is doing the same thing and I cant figure out the problem.
