Left Signal Light Problem
Bought a used 2003 Silverado a couple of weeks ago. The left signal light doesn't work sometimes - this is not a bulb problem. When pushing the left turn signal arm down it sporadically doesn't work. No pattern. It seems to lock up - sometimes the indicator light in the dash remains illuminated - sometimes it doesn't. When it locks up I push it back up into the neutral position and push down again and it works.
Its frustrating - any ideas as to what the problem is? |
Re: Left Signal Light Problem
Sounds like it could be a multifunction switch. At least this is what they call them on Fords. I work at a ford dealer and we see quite a few problems with multifunction switches, but not 100% on a GM. By the way, yes I own a 2003 Silverado and work at Ford.
Re: Re: Left Signal Light Problem
blacksilver, is your truck still under warranty? |
i would look at he plug for the left sig. there may be a lose wire or plug. also did thay install a plug for a trailer it could have a short. next run a ground from the frame to a mounting point neer the left turn sig. chevy's are good at bad grounds.
What would a mounting point near the left turn signal be? One more thing, sometimes when I push down the left turn signal arm and the turn signal indicator in the dash does not come on, I can get it to come on by pushing on the brake. As far as warranty goes, when I purchased the vehicle, I got a 3 month/5,000 km warranty. |
