Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 04-16-2005, 09:10 AM
Micheal1 Micheal1 is offline
Crashed My Intrepid Have Questions
I just crashed my 2003 Intrepid 2.7., 93,000 miles.The crash is in the right front side of the car (driver side). Apparantly the engine itself is okay, but i broke something that looks like a computer chip with a lot of of small pipes coming out of it. And behind that it looks like I banged up the computer.
I want to fix the car no matter what it takes even if it takes a new engine. So, I have a few questions and I would be very greatful if some one can help me out.
How much am I looking to pay if I want to replace just the computer?
How much to just upgrade the whole engine to a 3.5 or something?
( I think this is the best option because of the high mileage)
Any suggestion, comments, advice, opinion is welcomed, as I feel that I would get honest opinions at this site.
Thanks
Mike.
Old 04-16-2005, 06:41 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Crashed My Intrepid Have Questions
on the right front of your car, should just be the housing for the battery, unless you damaged your battery, you should be ok. If your engine isn't making any unusual noises, you should be in the clear as well, but if you want to throw in a 3.5 from an ES Intrepid and you have the money, go right ahead, some mods need to be done and a new computer is needed, but other than that, you should be fine. Just FYI, your engine computer is located on the driver's side fender by your washer fluid filler neck and (if you have cruise control) mounted underneath your cruise control actuator.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-03-2005, 04:58 PM
Re: Re: Crashed My Intrepid Have Questions
Actually I think thats the side the I hit. The side with the computer and the cruise control. I also bent the front axle pretty bad.
Old 05-03-2005, 07:25 PM
If you don't have any check engine lights, the engine starts up just fine and have no unusual problems, then the PCM is just fine, just replace the drive axle and get your fender and bumper replaced. As a precaution, you might want to take the car to a dealer or someone and have them pull up the readings on a scanner (or at Chrysler the DRB III) and see if all sensors are working and also that the PCM is internally ok.
