Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Vectra / Insignia
Old 04-16-2005, 07:38 AM
podgiekop1 podgiekop1 is offline
mass air flow sensor
hi guys just done paperclip test error code 0100 mass air flow sensor any1 tell me what to do now 98 vec cuts out under 1000 revs thanks
Old 04-16-2005, 12:13 PM
Re: mass air flow sensor
just got a mass air flow sensor changed it does not seem much difference does it take few miles to kick in still comin up as error code mass air sensor after i fitted it
Old 10-28-2005, 12:46 PM
ajc106 ajc106 is offline
Unhappy Re: Re: mass air flow sensor
hi just a quick question i have the same fault with my vectra did changeing the mass flow sensor work or have you found any other fault many thanks ajc106
Old 12-09-2007, 12:11 PM
pdub0429 pdub0429 is offline
if the error still comes up after replacing the sensor i would try checking the line maybe you have a loose wire or maybe one thats been disconnected?... im currently about to change out my airflow sensor in a ford probe if i have the same issue and i find a fix then ill let you know if its other wise
Old 03-08-2009, 08:53 AM
veccysri veccysri is offline
did u buy an oem mass air flow sensor or a cheap one or even worse get on from the scrappy
typical fault when the mass air flow goes is lumpy idling u can usually diagnose this fault by undoing the wiring connecter to maf meter if the idling revs settle then u know its deffo the meter at fault
u say it cuts out below 1000 rpm is this when dipping the clutch?
u might just need to clean the idle air control valve out on the side of the throttle body and the butterfly valve in the throttle body and checking all the pipe work around the throttle body for loose perished breather pipes
