Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 04-16-2005, 06:43 AM
AFDSKI AFDSKI is offline
97 MC Z34 Turning Clunk
Maybe someone could help me out? I Have Clunk sound when I Turn my wheel. the steering shaft problem was addressed some time ago by a recall. took it to the shop and they found nothing but heard it. I did put on a new wheel hub which they say is most likely the problem. anyone have any ideas?
Old 04-20-2005, 09:25 AM
dwalmop dwalmop is offline
Re: 97 MC Z34 Turning Clunk
it's probably the bearing plate at the top of the strut tower. Not a huge deal, but if/when you replace the struts in the front - replace those too. If it's a clunk when you're moving and turning - could be a CV shaft.
Great quote: "I am noticing a loud fuel odor"
Old 04-21-2005, 10:40 AM
EXTREME02 EXTREME02 is offline
Check your ball joints the will also make a clunking sound when your turn our at least mine did.
Old 04-22-2005, 05:50 AM
Re: : 97 MC Z34 Turning Clunk
Should have mention I replaced both ball joints and right wheel hub assembly. could it be the CV Shaft? the whole assembly (old) fell right out when I took the 4 hub bolts off. I pushed it back up and in with new hub.
Old 04-23-2005, 04:43 PM
Re: Re: : 97 MC Z34 Turning Clunk
Check your CV shafts. have you replaced our checked you tie rod ends as well?
