Old 04-15-2005, 11:19 PM
capetonian capetonian is offline
Question 91 astro died - wont start - electrical?
hi all,
i have spark and fuel, spark may be weak, fuel seems strong being injected in spurts
timing seems as if it could be off, firing / detonation in exhaust, but it will not start
checked ignition module - ok - thanks autozone for the free check
fit hei distributor, fires up first swing, but dies as no fuel - but thats just as the hei does not talk to the rest of the electrical system
so i am presuming i have a weak spark - coil - but if that is so why does it seem to have timing that is off?
is there a crank position sensor on these old motors? if so where and could it be that?
what else could it be??
Old 04-24-2005, 10:11 AM
chevy94 chevy94 is offline
If the engine has high mileage, it could possibly one of these:
Engine timing chain has broken
The Ignition module located inside the Distributor is bad
Ignition Coil is bad
Faulty fuel pump (not enough fuel to start engine)
Last resort--take the vehicle to the GM dealership and have them locate the problem... good luck
