Old 04-15-2005, 11:09 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Oil pressure might be low and I have a little leak.
When I was last at the shop they discovred a tiny oil leak, not on the transfercase or pan or transaxle, somwhere up in the engine.. There is never any oil in the driveway at all and the ammount of oil never drops at all on the dipstick but its still there a little, when they mentioned that I said that I thought the pressure might be a little low since it seemed lower on this car than on the SL I had. They hooked it up to a real oil pressure gauge and they said that it was just within spec and that they wanted to go in and find out what was leaking, I think they wanted to check the pump too. The oil gauge if left at idle for a little while is like 2-3 of the small bars from the bottom which seems very low to me, at regular driving RPM (like 2k) its around the middle near the first thick bar from the bottom, when I rev it up a bit it rises a little from there. Should I be worried, I don't have the money for them to disect my car let alone replace anything, I've got just enough to buy a downpipe which will fix the ricy sound and I'd prefer to do that instead of saving up to fix a problem that might not even be a reality.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 04-15-2005, 11:53 PM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
Re: Oil pressure might be low and I have a little leak.
If the oil pressure is raising when you are reving it up, there might be some kind of bad connection with your gas and that guage.. although if there is a leak.. and you know about it that might even be the problem. You should get it looked at, because if you run low on oil, dont know about it, you could easily blow your engine in no time. Just trying to help, may be right or might not be.
1991 Dodge Stealth R/t
Old 04-16-2005, 02:18 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Your oil presure will be low at idle, esp on the stock gauge. As long as its not all the way at the bottom during idle your fine. I think mind was just above the first large mark when crusing.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-16-2005, 03:56 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
my car has the same problem. a small leak, but i see no oil leak from th bottom, no matter how long i lay on the ground and watch. but it was loosing oil a little to quick, so i knew it had a leak, just didnt know were it was coming from. eventually i found it started driping from the.............the..........i'm sleepy, i cant even remember the name of it, the damn seals from the....
the hell with this i'm going to sleep. i'll tell you in the morning
Old 04-16-2005, 12:38 PM
Thourun's Avatar
Lol, I'll take a pic of it at idle later on, I want to change the rear plugs and wires today.
1995 3000GT VR-4
Old 04-16-2005, 01:09 PM
pr0ject01's Avatar
Does the 3000 GT or the Stealth burn oil like crazy? Or.. would that be a leak like you guys are talking about...?
Old 04-16-2005, 04:15 PM
Bo240sx Bo240sx is offline
Send a message via AIM to Bo240sx
i know alot of the 3000GTs have oil leaks from the oil cap... it seems to me that my boyfriends 95 3000GT SL oil pressure seems really low at least thats what the guage reads but then again you can never tell since theres no acual numbers on the guage haha
Yea...its a Chick Thing
But ya girls who drive imports, lifted trucks, and even girls who drift are the hottest!!!!
^ ^ Well said ^ ^
Old 04-17-2005, 12:47 AM
Thourun's Avatar
Re: Re: Oil pressure might be low and I have a little leak.
I've had two and neither ever burned any oil, its just a tiny leak, I don't think I'll do anything about it (knock on wood).
1995 3000GT VR-4
Old 04-17-2005, 01:23 AM
youngvr4's Avatar
STREET RACING GURU
the valve covers, thats where the oil was leaking from. and the oil cap
Old 04-17-2005, 09:32 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I had a slow leak from the oil cooler a few years back. One of the hoses had a small crack in it.
Resistance Is Futile (If < 1ohm)
Old 04-17-2005, 09:37 AM
Gateway's Avatar
Gateway Gateway is offline
i have a leak in my front valve cover, which is getting fixed soon. parts/labor is $100
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 04-17-2005, 12:05 PM
sLADe781 sLADe781 is offline
Mine comes from my oil cap because there's always a nice spot of fresh oil around the area. Don't really know what I could do to get rid of it... :o/
Old 04-17-2005, 03:19 PM
Thourun's Avatar
The cap isn't very leaky, but I am getting a new front valve cover because mine is peeling and awful looking from a guy who lives near me on 3SI... Hrmm I should call him.
1995 3000GT VR-4
