Go Back   Automotive Forums Car Chat > Toyota > Tundra
Old 04-15-2005, 10:05 PM
Macko Macko is offline
Need improved gas mileage
This summer I was thinking about investing in a cold air intake. I don't know much about automobiles and usually leave much of the stuff up to my dad, but I was wondering what brand would you recommend for a cold air intake? The only brand I recognize is K&N, but as I said before I don't know much. I would imagine they are all relatively the same in performance, but I noticed some price difference. Please let me know. Thank you.
Car: 2000 Toyota Tundra, V8 4.7L
Old 04-16-2005, 12:26 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Need improved gas mileage
They are all relatively the same for performance - no improvement documented. Save your money. Exhaust improvements are more profitable and actually do something for performance and mileage. You can also go for a TRD or AMSOIL air filter. They are high quality and do much more than the cold-air intakes. They won't increase your mileage, but they will give you hp.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-16-2005, 04:06 PM
Could you direct me to a site that has these air filters.
Also, what would you recommend for exhaust? I think I would like to have it cut off so it wouldnt show. Probably would like to spend $300-$600 on it. Let me know, thanks.
Old 04-17-2005, 01:09 PM
Brian R.'s Avatar
Resident Chemist
https://www.amsoil.com
or
http://www.trdusa.com
For exhaust mods, I would go with a cat-back system from TRD or other reputable manufacturer (search these forums) or headers plus a custom exhaust if you want to spend some additional cash, but really want some improvement. You can use one of the quality cat-back systems as a basis for your custom exhaust, just couple up a high-flow cat converter to your headers and join it to a cat-back system.
Old 04-20-2005, 03:32 PM
How would I benefit more from an air filter than cold air intake? I will probably get exhaust sometime next year, but for the time being would an air filter and cold air intake noticeably improve my performance?
Old 04-20-2005, 03:44 PM
Also, what do you think about Throttle Body Spacers or Helix Power Tower?
http://www.performanceproducts.com/C...cid=17#product
Old 04-23-2005, 02:31 PM
Brian R.'s Avatar
Resident Chemist
Re: Re: Need improved gas mileage
The filter (TRD or AMSOIL) is much more efficient than most any others, both in particle size and airflow. Better performance.
Cold air intake limits your choices of filters. You are better off with an excellent filter and the factory intake than the other way around. You can improve the efficiency of the factory intake system also.
Again, improvements in the intake won't help your gas mileage. Only adds power. Letting more air in just permits your engine to use more gas. The more gas, the more power at any particular throttle setting. Cruising at 60 mph will require less throttle opening, so it all averages out. More gas, less throttle. The exhaust improvements actually make your engine more efficient and improves mileage.
Old 04-23-2005, 02:33 PM
Brian R.'s Avatar
Resident Chemist
I have a very low opinion of both of them.
Old 04-23-2005, 07:27 PM
Re: Re: Re: Need improved gas mileage
In that they don't work or just a waste of money?
Old 04-24-2005, 11:41 AM
Brian R.'s Avatar
Resident Chemist
Both
Old 08-09-2005, 03:14 PM
travelair travelair is offline
Intake manifolds on many engines are heated to improve economy. Hot air is less dense therefor less fuel (leaner mixture) is needed for the same volume of air.
