Old 04-15-2005, 09:07 PM
RBeach's Avatar
RBeach RBeach is offline
Question Help! Strange Problem!
1996 3.8L, when in reverse, sometimes the engine will shut off when turning sharply or sometimes even lightly. Today, it actually did it in drive when I turned into a parking place. Any ideas?
By the way, I have already tested and verified the front IMRC is bad, and when funds permit, will be replacing it. But, I wouldn't think these two would be related, as the cutting off problem recently started.
Rusty
Old 04-16-2005, 08:28 AM
12Ounce 12Ounce is offline
Re: Help! Strange Problem!
Since the IMRC actuator is known to be bad: try removing, and plugging, the vacuum hoses that go to the actuators. A bad leaking actuator diaphragm could affect the low-rpm performance of engine.
You could also block the IMRC in the actuated postion ... which is the low-rpm position.
Old 04-22-2005, 07:39 AM
head_bum head_bum is offline
Lightbulb IMRC Repair
I had just purchased a winnie at auction and had several problems with it. One of which was the front IMRC. Since I am kinda thrifty and decided that I might try to put my education as an engineer to work (since my career path has not forced me to do so) I was able to fix my IMRC. The first ting I did once I removed it is cut the rolled metal cap (for lack of better descriptive terms) in about 4 places equally spaced at approx 90 degree intervals. Then roll the new tabs out. That allowed me to get access to the diaphram. It was torn. I blue rtv the crap out of the edge of the diaphram all the way around the cap. The placed the cap back on the body and rerolled the tabs back down around the body. Put another bead of blue all the way around the cap and body assembly and once the rtv was cured worked good as new. One thing that must be noted before this is the position of the linkage arm with relation to the position of the assembly. I completley tore the diaphram during disassemble so had to realign. One thing in hindsight that i might had done is matchmark the cao to the body this would eliminate this problem as long as the diaphram is still somewhat intact. good luck.
Old 04-23-2005, 01:26 AM
CoachKarl CoachKarl is offline
Head Bum. YOU are an artist. Please keep us posted as to how long this fix last.
Old 05-18-2005, 08:56 AM
IMRC still picking up when vacuum applied...so far so good
Old 10-27-2005, 11:04 AM
IMRC still working.
Old 05-01-2007, 09:21 PM
IMRC Crapped out in Feb. Was able to get functioning unit from the ol junkyard for 6 bucks.
