Old 04-15-2005, 09:02 PM
lacycosmo lacycosmo is offline
help!!!!!!!!!
ok i got the steering column removed and replaced! I reconnected all the wires. Now when i turn on the key i get all the accessory stuff but the car will not turn over and i get a security light that stays on! Any ideas?ty
Old 04-15-2005, 10:51 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Re: help!!!!!!!!!
The Wire At The Switch Is Broken You Need A New Switch
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 04-15-2005, 11:00 PM
Re: help!!!!!!!!!
You Could Also Get An Ohm Meter Get The Ressistance Of Yer Key And Plug A 99 Cent Ressistor In Under The Dash Their Are Two White Wires With A Orange Sleve Over Them Comeing From The Column To Under The Dash You Would Put The Ressistor In The Plug Going To Under The Dash This Is A Quick Easy Way To Fix This I Did It On Mine Almost A Year Ago And Have Had No Problems
Old 04-16-2005, 08:18 AM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
Re: help!!!!!!!!!
Why are you capitalizing every first letter of every word!
Old 04-16-2005, 08:25 AM
Re: help!!!!!!!!!
for some reason it dose it automaticly when caps lock is on
Old 04-16-2005, 08:59 AM
ty
thanks for the help i will try replacing the switch
hope it works!!!!!!!!!!
