Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 04-15-2005, 08:07 PM
Dagger99 Dagger99 is offline
88 Harmonic Balancer?
Can antone tell me how to remove the harmonic balancer off a 1988 Olds 88 3800 FWD?
Old 04-16-2005, 03:13 AM
chevelleman chevelleman is offline
Send a message via AIM to chevelleman Send a message via MSN to chevelleman
well your going to have to first take the plastic shields that cover up the flywheel because you are going to need to have someone hold a screwdriver in one of the teeth on the flywheel up against the housing so motor wont turn and then get a socket and a good sized cheater bar on there and turn the bolt counter clockwise because it is left handed threads and its going to take some effort because they are really on there once you get the bolt lose the balancer to slide right off pretty easily because its not pressed on or anything
Old 04-18-2005, 04:31 PM
monstertaco monstertaco is offline
Get a manuel, it should have it in their, it will (hopefully) go step by step with pic's. good luck.
