Old 04-15-2005, 08:35 PM
vampiro03 vampiro03 is offline
arghhhhh! I can't figure it out!
I have a 96 taurus with a 3.0 over 100k
im usually good figuring out whats wrong with my car but, this one's got me stumped. first off, the code p0430 the catyletic system below threashold bank 2 bla bla bla, theres a million different things that trip that sensor. heres how the car acts: long start maybe 15-20 turns, fires up faster with a full tank of gas, the cat is overheating(I can smell it). the temp guage fluctuates a LOT. mostly when I have my foot off the gas and comming to a stop from highway speeds the temp guage starts filling up. after I turn the car off, if I start it up like 3 mins later the temp will show like 85% hot after being off. it always circulates back down though. new water pump(it was squealing), egr valve, pcv valve, plugs wires and coil pack. could the cat be plugged? I was thinking about replacing the coolant temp sensor but I think the cat is the heating problem, maybe a fuel pressure regulator? man! I don't know!
Old 04-18-2005, 02:41 PM
GPFred GPFred is offline
Re: arghhhhh! I can't figure it out!
I would take it to an exhaust shop about the cat. They would be able to tell you if its blocked up. As for the temp, I would look at replacing the thermostat and maybe the temp sensor. Is it throwing any codes?
Old 04-18-2005, 03:55 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Yea i would also get the cat fixed, if could be throwing off your entire system, if might also be your radiator, they begin to go around that time.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-23-2005, 02:23 PM
bdog_840's Avatar
bdog_840 bdog_840 is offline
Its gotta be an exhaust restriction.
Old 05-10-2005, 11:30 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Re: arghhhhh! I can't figure it out!
But what's causing the exhaust restriction? Too rich an air/fuel mixture? Could be caused by bad plugs/wires, bad oxygen sensor(s), bad coolant temp sensor, sludged MAF sensor elements, etc. Just replacing the converter may not fix the problem, something likely caused the converter to go bad (if that's the problem) in the first place.
If you find restricted exhaust, verify all other systems are working properly.
-Rod
Old 05-11-2005, 03:21 PM
Psychopete Psychopete is offline
Re: Re: Re: arghhhhh! I can't figure it out!
-Rod
I agree. Hot cat = running too rich. Check a spark plug or 2 to verify that it's running rich. Have you noticed a decrease in MPG?
When your car is off, it can't cool anymore. All of that heat under your hood stays there and increases the temperature of your coolant. This is why it went up to 85%, but that seems high. Perhaps the exhaust manifolds are getting hotter than hell? I would crack the hood after coming home from work or what not and let all of that heat out before something gets warped. A machined lower intake manifold runs about $120. But in my case I got it for $85 since the buttheads told me I wouldn't have to get it milled when I milled my heads .030" on a 60 degree Ford.. I was pretty upset when I found water in my oil.
Pete
Old 06-23-2005, 08:53 PM
well, I finally figured it out. I had a bad plug/wire. that was tripping the sensor. the starting thing is definately a lack of pressure in one of my cylinders. the first one I checked with the pressure guage read about 90!! and missed jumps! all the other cylinders were at LEAST 160! so, one bad cylinder = not head gasket, but it could be a cracked block or piston ring. how do you diagnose a pressure leak?
Old 06-23-2005, 08:58 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
best way to do it without tearing the engine completely down is a leakdown test
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 06-23-2005, 09:18 PM
what do I need to do a leakdown test?
Old 06-23-2005, 10:24 PM
now, I found a leakdown tester online. I have two really crazy questions. 1.can you change piston rings without removing the engine?
2. how can I tell the difference between a bad piston ring or a cracked block without ripping it appart, is the tester THAT percise?
Old 06-23-2005, 11:03 PM
drdisque's Avatar
with a bad piston ring the leakdown should be pretty solid whether you move the crank or not, but with a crack in the block, the leakdown should change as you move the crank.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
