Let's talk HVAC
Ok, my '02 has 28,000 miles on it, and it is just about out of warranty, I am compiling a list of things to have fixed before my warranty runs out. Now, on my HVAC system, when the "recirculate" option is selected, I can still smell things from outside, likesmoke and diesel exhaust. Also, I noticed that if it is in "recirculate" and then I turn the system off, it still blows in air from outside. I don't think this is normal, as NONE of the 9 other cars I have owned have done this. How do the systems in your trucks function? Does it behave like mine? Also, someone here posted that the passenger side rear window on an extended cab let in a lot of air when on the highway. I went to Florida last week, and mine seemed to be doing this, too. Did the dealer take care of this? Thanks!
Re: Let's talk HVAC
when I took mine to the dealer for the window problem, they told me I had bad seals. They then proceeded to say that the only way to replace the seals is to replace the entire window. Since my warranty does not cover glass the total cost for repair would be $750 , yes three quaters of a thousand dollars, for both sides.
Needless to say I just simply turn the radio up a little louder. F**K'N dealership.....
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not."" -George Bernard Shaw "Mind over matter: If she doesn't mind, It doesn't matter" -Nineball
Re: Re: Let's talk HVAC
Thats a heck of a lot of money for window replacement. You should talk to your local body shop.
2009 Silverado 1500 2002 Camaro Z28(rebuilder) 2005 Yamaha GP1300R |
Re: Let's talk HVAC
What about your HVAC systems?
Re: Let's talk HVAC
i can have mine turned off completely but still get air blowing in when cruzing along.....of course when i am stopped at a light or something i dont feel it then.mine has done this since day one. i just thought it normal though other vehicles i have owned (including other chevys) when it was turned off no matter if i was cruzing along or at a light i didnt feel air blowing out.
2002 Z71 ext. cab LT trim badgeless Rhino spray in liner Stock for now, other than free mods future plans (how far in the future depends on wallet) Toyo Open Country M/T's air intake (not sure which yet) exhaust system (seems that Magna flow is the ticket) Nelson tune 3 or 4 inch lift |
Re: Let's talk HVAC
I could be wrong but, I do think I remember reading in my owners manual that when the a/c system is off that fresh air from outside will be forced into the cabin. Read your owners manual.
Re: Let's talk HVAC
Ok, but has anyone noticed fresh air getting in (i.e. smoke or diesel exhaust) when their system is on recirculate?
Re: Let's talk HVAC
Negative.
Re: Let's talk HVAC
Listen for a clunk when you switch to Recirc. On mine when I switch to Recirc I can usually hear the door closing on the fresh air intake. You may have a sticky motor for closing the fresh air intake or dirty or something. Have a listen...and see what you hear. RECIRC doesn't work IN DEFROST MODE. Mine will not allow Recirc when in floor/Defrost or just Defrost. So, make sure you test it with the vents or floor settings.
Hope this helps.
2008 GMC ACADIA SLE Edition, 7 passenger model I AM Canadian!! ![]() |
Re: Re: Re: Let's talk HVAC
...make that 1st worst extended warranty. covers electronics, motors, drivetrain, pumps, and other stuff. The truck is covered to 96,000miles or 3 more years. I think I will have a magic oil leak around 90,000 where all the oil in the engine disappears long enough to toast the engine, then magically reapears in the block right before I take it to the dealer for a new engine.
Re: Let's talk HVAC
if it is in recirculate mode even with the system off there should be no air entering the cabin
2001 Silverado Extended Cab LS V-8 Rare Sunset Orange Metallic |
