Go Back   Automotive Forums Car Chat > Automotive Art > Remote Control Cars
Remote Control Cars Questions, comments or discussions on the wonderful little vehicles.
Old 04-15-2005, 07:05 PM
NewyorkKopter's Avatar
NewyorkKopter NewyorkKopter is offline
How fast does a TC3 go with a 13T motor
Hey, I was just wondering. I have a TC3 running a 13 turn motor with 23 tooth pinion. With a 19 Turn the TC3 goes about 20 mph. I seriously doubt mine with a 13 turn is going even 30. Can anyone please give me a estimate on about how fast it goes. Thanks
List of parts in TC3
-TC3 Racer Kit
-Aluminum Driveshaft
-1800 mAh Battery Pack
-Duratrax 12T ESC
-Orion 13x2 Turn Motor
-Futaba Magnum Sport Radio System
-23 tooth pinion gear
-Stock spur gear
Old 04-17-2005, 08:53 AM
turbo type-r's Avatar
turbo type-r turbo type-r is offline
Re: How fast does a TC3 go with a 13T motor
30 to 35 geared right
lac - 80 % done baby!
Old 04-22-2005, 05:50 AM
Hi, what exactly do you mean if its geared right.Also, is there a way that I can make it go 40 mph without changing the motor. Thanks
Old 04-23-2005, 12:40 PM
PSYCHORACING PSYCHORACING is offline
What orion motor is it? The new V2?
Old 04-25-2005, 10:23 AM
its a Orion Rush 13x2
Old 04-26-2005, 10:30 AM
Lamboholic Lamboholic is offline
Hi, you can increase speed by using different cells. I wonder which cells do you use now? Softer tyres increase traction which your going to need.
Ultimatly would be a brushless motor and a big ESC on hot cells GP2200 would do just fine.
Old 04-27-2005, 07:14 PM
You dont need a Brushless to go fast. You can push 40 by messing with gear ratios, and its the cheapest thing you can do right now. Just make sure the motor doesnt get too hot.
Old 04-29-2005, 09:39 PM
how do you mess with the gear ratios??? I'm using a 7.2v 1800 mah battery.
Old 05-14-2005, 09:40 AM
gear ratios meaning using bigger pinoins and different size spur gears and if you want to hit 40 you should run like 3300 gp cells that are good
