Old 04-15-2005, 04:41 PM
Colo Colo is offline
'92 with Death Wobble
I have a '92 that starts to shimmy a bit when I hit 50-60 mph. Also happens occasionally when I hit a pot hole at lower speeds too, 30 - 45 mph. You can also hear a grind when making u-turns to the left. The wobble usually stops if I accelerate through and get up to 65-70 mph, but it still make me nervous.
How dangerous is it to drive in this condition? Could my tie rod break and the wheel fly off or anything? I don't usually have to drive on the freeway, so this problem rarely comes into play. Given the symptoms I described, is there anything particular I should check first?
Any ideas will be appreciated..
Old 04-15-2005, 07:52 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
do a thread search, this topic has been covered before and there are some good posts regarding this topic
Old 04-16-2005, 03:19 AM
Cam7 Cam7 is offline
The 2 main Items that cause Death Wooble are the Steering stablizer and Control Arm Bushings Upper and lower. Yours sounds like you might have a bad Hub with the Grinding noise. Also check the Axle U joints for wear and your Tires for balancing. Jack up the front end and turn the wheels and listen for any distortion. Make sure you use Jack stands.
Old 04-18-2005, 06:49 PM
paulsenior paulsenior is offline
Tire balance
Check tire balance my jeep did the same thing at about the same speed. May not be the total problem but is the cheapiest fix
Old 04-19-2005, 08:52 AM
Thanks for the feedback. Any opinions as to the urgency I should have in repairing this problem? Is this something that is just annoying or is it a possible safety issue? I have limited time and funds to do any repairs, so I've been putting it off as long as possible..
Old 04-19-2005, 12:09 PM
Fix it
Try to get it fixed asap, those vibes can really mess up your rig things can come lose, it will wear out your steering stabalizer. My friend had a problem like this on his chevy, ended up being the drop pitman arm. But for sure get it fixed ASAP just my Paul
