Old 04-15-2005, 03:09 PM
01Blackerado 01Blackerado is offline
Send a message via Yahoo to 01Blackerado
FS: Transgo Shift Kit 99+ 4l60e
Transgo shift kit $80.00 shipped!!
Old 04-18-2005, 09:55 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: FS: Transgo Shift Kit 99+ 4l60e
is this the heavy duty unit?? I've been looking for one of those.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-18-2005, 11:23 AM
No sir, Sorry J. how's your truck runnin anyway?
Old 04-19-2005, 06:36 AM
jeverett's Avatar
It's doing very well! I haven't had a single problem after the engine swap. I can tell that the engine is a newer model from my old one, and I need to get Allen to tune me a '02 PCM to really wake it up. I've been wanting a shift kit so I can get all of my Torque Management removed.. would your kit allow me to do this, or is the HD kit the one I need?
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-19-2005, 08:09 AM
To remove all the TQ management I, just my 2 cents, advise getting the tranny completely built for it so therefor there's no problems at all!! But alot of people take it off even without the shift kit at all and do just fine! Being that you have a regular cab, it will be alot easier for you to get away with it, without having to build the whole tranny! How much power would you guestimate that you have out the motor!? If not alot(330hp, 370trq) then you might be fine with no upgrade at all!! If you think you have anywhere near more than that, then you need do something before you remove it all( Shift kit + Servos, Servos + accuator, or the whole build up)
Old 04-19-2005, 10:11 AM
jeverett's Avatar
So far, here's all I've done.
Stock 2002 engine..maybe out of a Tahoe I think.
K&N FIPK. throttle body bypass, shaved the egr tube (gunna get allen to delete it) the Flowmaster cat-back, and the tune.
Trying to get some e-fans soon if I can find a good deal on some. And some Long-tubes if i can find a deal also.
So I dunno where to start estimating how much power....if you gan guestimate with those bolt on's..
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-19-2005, 10:27 AM
If its a 5.3 then id say right around 32x HP 36x Trq
Old 04-19-2005, 10:29 AM
So you should be fine without the kit at all but again, its risky, the shift kit i have will help out but it wont be the answer to all if any problem pccured with all Trq managment removed
Old 04-20-2005, 06:35 AM
jeverett's Avatar
Well dang man. I was looking forward to having one!! They don't cost too terribly much though do they? I've seen a bunch on e-bay, but I don't know the part # for the HD kit. I also thought about getting the kit and a servo from Allen.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-20-2005, 07:28 AM
Thats definatley an option for ya
Old 04-20-2005, 04:34 PM
bowtieguy bowtieguy is offline
Re: Re: FS: Transgo Shift Kit 99+ 4l60e
Jayson you mentioned throttle body bypass, and shaved egr tube. what exactly are these mods? how simple are they? what improvements are there from doing these mods?lets see any other questions i can ask....no thats probably enough. sorry about all the questions i have heard of a few free mods but never heard of those two, if they in fact are free and you are not talking about bolt on mods.
2002 Z71 ext. cab LT trim
badgeless
Rhino spray in liner
Stock for now, other than free mods
future plans (how far in the future depends on wallet)
Toyo Open Country M/T's
air intake (not sure which yet)
exhaust system (seems that Magna flow is the ticket)
Nelson tune
3 or 4 inch lift
Old 04-20-2005, 05:18 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Hey im gettin a Nelson tuned pcm here as soon as i get my next set of tires and i was wondering too about if i should get a shift kit for my truck to give the old tranny (origional 4l60e) a lil added strength. I want to get one put on any way but was just wondering if any of you had any input as to which kind to get....
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 04-21-2005, 06:51 AM
jeverett's Avatar
Re: Re: Re: FS: Transgo Shift Kit 99+ 4l60e
The throttle-body bypass is where you take the coolant line that is running through the bottom of the throttle-body, and splice it together with a brass coupling. This keeps hot water from going through the TB and theoretically makes for cooler air entering the engine. I'm not sure how much power it gains, but it's only like $.50 or so to do.
The EGR shave is where you take the ERG tube out of the intake, cut the end off so it's flush with the intake when you bolt it back on. I don't think it makes for much of a gain either, but heck, I figured they are both free, or nearly free and they can't hurt anything.
I also de-screened the MAF, which I wish I hadnt done. The screen is too bent up to put back in now
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-21-2005, 11:44 AM
Re: Re: Re: Re: FS: Transgo Shift Kit 99+ 4l60e
Does sound logical cooler air fuel mixture. i see you have a 99 there isnt any difference for an 02 is there? i have already removed my MAF screen and modified my air box and duct too.thanks for the info Jayson.
badgeless
Nelson tune
3 or 4 inch lift
Old 04-21-2005, 11:54 AM
jeverett's Avatar
No problem man, anytime.
Theres not one bit of difference between the two
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
