Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 04-15-2005, 02:52 PM
suniths suniths is offline
Factory amp in 95 cirrus
I am trying to install an aftermarket cd receiver in my 95 cirrus. I think i may have to bypass the amp. Can anyone tell me where the amp is located, if there is one ???
thanks
Old 06-07-2005, 05:16 PM
KENNETH HUBBARD46 KENNETH HUBBARD46 is offline
Send a message via AIM to KENNETH HUBBARD46 Send a message via Yahoo to KENNETH HUBBARD46
Re: Factory amp in 95 cirrus
thanks
My wife has a 95 Cirrus, I think the amp is located under the front passenger seat.
CHRYSLER POWER
Old 06-11-2005, 01:06 PM
annguyen1981 annguyen1981 is offline
Send a message via AIM to annguyen1981
I have a 2000 Cirrus, and the factory amp is located under the front passenger seat.
Old 06-13-2005, 09:53 PM
InstallTech's Avatar
InstallTech InstallTech is offline
Actually, if you just power up the amp at the radio's wire harness, the speakers will work fine. If you suspect a problem with the amp, then go ahead and bypass it. If not, then just power it up. Just make sure to hook up the amp turn on lead from the new radio to the blue wire on the wire harness that plugs into your factory's wire harness. Otherwise, it's a lot of re-wiring to bypass that amp.
I reject your reality, and substitute it with my own.
