Old 04-15-2005, 12:10 PM
kjewer1 kjewer1 is offline
AF - Advisor
New exhaust
I have a boner for my new exhaust on the truck, this is the 3rd forum I've posted it on. Pics and info here http://www.posracing.net/POStowrig.html
Trucks are way cooler than DSMs...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-15-2005, 12:14 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: New exhaust
Man, that exhaust is PIMP!!!
Way to go man, it looks great! I know you are going to love it.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 04-15-2005, 12:22 PM
AF - Advisor
Re: New exhaust
I'll love it more when I get injectors or a fueling box, and that 5" tailpipe is billowing out massive amounts of black smoke. First task is to smoke out this entire condo complex that I live in, just because I hate everyone that lives here
Kevin Jewer
Old 04-15-2005, 12:31 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: New exhaust
I've never seen a 5" exhaust before. That looks intimidating to say the least. Since the truck's a diesel, would all the turbo basics (spooling, clip or not, boost spikes and creep, etc etc) that apply to gas driven DSMs still hold true for the truck?
(I wanted to word the question differently so it made more sense, but can't put it together right!)
The daily driver. The weekend cruiser. The lazy shop hog.
Old 04-15-2005, 12:56 PM
AF - Advisor
Re: New exhaust
Diesels are very different. Raising boost, increasing airflow, etc, dont necessarily produce power as they do in our application. Its all about burning fuel. In fact there is no air throttling done at all. The gas pedal is connected to the fuel pump There is also no real boost control. The wastegate is more of a pop off valve, simply limiting maximum boost. Many diesels have no wastegate what so ever, and you have to be careful not to over spin the turbo. The more fuel you burn, the more boost you get, and thats how you get more air. Adding too much fuel will increase EGTs, the safe limit for the cummins turbo diesel is considered 12-1300 degrees F. If EGTs go over that you need to reduce fueling, or increase airflow. So the larger exhaust will allow me to add more fuel before EGTs get too high. Still need to find a way to add that fuel though. Injectors, chip/box, etc.
Kevin Jewer
Old 04-15-2005, 03:01 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: New exhaust
good choice with the dodge kevin.
i like trucks better than cars too. Yet i still want a turbo dsm. I guess they just got it in for me.
Pictures of the Truck
Old 04-15-2005, 03:43 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
dam 5inch,i thought 4inch was the upgrade but 5 inch is nice!hows the sound on that bad boy?
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 04-15-2005, 04:33 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: New exhaust
WOW...."that's a huge bitch" duece bigalo......nice exhaust
I saw the drum and thought... damn that is one hell of a redneck salad bowl!!! lol
You should post some audio of the exhaust when it is all done....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-15-2005, 06:17 PM
Shpyder's Avatar
Moderate moderator
Re: Re: New exhaust
I thought so.
We used to have a 1990 4-dr Mitsubishi Pajero (Montero) that was a turbo-diesel, intercooled 4G64 SOHC (RWD, 4WD-on-demand), 5 speed manual. That thing had insane torque for the 2.4 litres of miniscule displacement, and out-drag most pertol cars on the road. It had a big sticker from the factory on the said that read "turbo wagon". I never really understood back then what a turbo did, but now that I recount, the SUV pulled like it had a supercharger all the way to red line (ie to say, linear acceleration, no peak boost accompanied by whiplash... redlines on deisels are really low, 5K in this case). There was practically no BOV sound, and spooling noises where often muffled out by the diesel engine except for high gears (oddly so). Considering the very high compression ratios on deisels (which is why no spark is needed to ignite the air/fuel mixture...the heat alone is sufficient to do the job, and glow plugs help when initially starting up), I don't think the turbo put in a significant amount of boost, but it sure pulled like it was on steroids.
We also had a 1993 1.8 litre RWD turbo-diesel Nissan Sunny (Sentra) that was pretty cool for drifting around local city blocks. lol. Diesel seems to be the cheaper fuel in both Europe, and large parts of Asia, hence a lot of cars were manufactured with deisel engines. The best diesel I have ever driven is a 4.5 litre turbo-diesel Toyota Landcruiser (called the "VX limited" in SE Asia)... you had traction issues all the way up to THIRD gear if you were really pushing it!
Old 04-15-2005, 07:36 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: New exhaust
sweet so when are you putting a 5 inch on your gsx?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-16-2005, 03:10 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Re: New exhaust
LOL i'd love to see that happen.
Old 04-16-2005, 03:35 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: New exhaust
At least they say diesel exhaust is less toxic than that of a gasoline engine. I'm aware of how much black death can be made from a cummins diesel. Good luck. When are you going to tell us what the plans are for the 1g?
Old 04-16-2005, 08:08 AM
Gsx_hooptie Gsx_hooptie is offline
Re: Re: New exhaust
5" exhaust has bragging potential. Or ricer envy
Size matters. I like how everything is bigger on American cars with plenty of room to work. No pita in trying to reach what you're working on, either. I'm halfway through removing the AC and I'm already happier
What's up with the recent posts about getting out of dsms, getting old and fat, needing an evo, ultimatums with Mitsu bankruptcy, etc? And if you leave dsms for a truck I'm not sure what to say, lol.
Diesel gets better mpg and is more efficient but is a hell of a lot more dirty, even considering the better mpg. BAU lobbied against it's regulation until the 90's, even though the EPA knew it was toxic since the 70's. Bad times, that stuff runs school busses.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 04-16-2005, 11:08 AM
Shpyder's Avatar
Moderate moderator
Re: Re: Re: New exhaust
Diesel is "dirty" in terms of actual, visible soot and carbon it gives out (really black exhaust fumes VS the more liberal white/non-colored gases out of pertoleum). However, I have HEARD that its toxic content is in fact less damaging to the ozone and environment than pertol fumes.
Also, biodeisel is an amazing new alternative to deisel. It is cleaner (exhaust smells like FRENCH FRIES, would you beleive!), much cheaper, and gets even better mpg than regular diesel. This diesel is extracted straight from soybeans with minimal modification to form and content.
The mindboggling thing is that biodeisel can be added to ALL existing diesel engines without any modification whatsoever. Truckers across the country have started using it, though the frequency of biodeisel refueling stops is scarce at this point in time. You can LITERALLY pick up a bottle of Canola cooking oil, and run it right off Vons shelf in an emergency (will burn bad, but not enough to hurt engine, will get you from A - B without issues).
Unfortunately, America can only reserve land enough to supply 130 million gallons of the fuel...truckers alone use 40 billion a year, so thats going to be a problem.
Just thought I'd share some stuff I spent hours listening to on Coast-to-Coast AM with George Noory. It's pretty neat.
Old 04-16-2005, 02:01 PM
Re: Re: Re: Re: New exhaust
Kinda in line with my major, learning a bit about this stuff. I can't pretend to know much. Mostly because of better mpg, co2 emissions are lower with diesel, which is responsible (at least if you're a democrat) for global warming. Particulate emissions are worse from diesel, which is closely tied with lung cancer. Shypder said all this, and I agree. Trucks and busses that run on diesel have no mandatory smog checks and aren't held to the same requirements of cleanliness that gasoline engines are. There are different tiers, gets kind of complicated. CARB thinks burning diesel causes 14000 premature deaths in CA alone. Sulfur emissions are really bad, so the mix of diesel is being reworked, and the DOE study says that 20% more oil and heat trapping gasses will result from the new mix, making it much less environmentally conscious than gasoline. Nitrogen emissions are worse, too, which are responsible for ozone depleation. Umm, I don't wanna jack this thread, anymore than I already did. If you want to hear more of my tree hugging propaganda, let me know
Back to 5" diesel loving exhaust
