Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-15-2005, 09:38 AM
risingernicole risingernicole is offline
power windows
Does anyone know where to find a diagram of the power window setup on a 91 probe lx? I think the cable may have come off or something. The window just dropped and I can still here the motor running when I hit the switch.
Old 04-15-2005, 10:01 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: power windows
wow u have alot of problems with your probe... Um pretty sure its supposed to make a sound if you hit them button when they windows already down. If it doesn't come back up it means your clip fell out. If it doesn't do anything up or down it's probably that. There isn't no real diagram on the wiring and the door, other in the cars manual that you have to purchase at a parts place, or take it to a pro/
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-15-2005, 11:42 AM
Re: power windows
Yeah basically. Its a 91. Runs fine. Just little shit going wrong. The horn never worked. The headlight was stuck down, but I got that fixed. Going to work on the window today then try to figure out the horn. Is there a relay for the horn anywhere? I know there is a fuse, that is fine. But the wiring diagram I have says there is a relay too. Just don't know where.
Old 04-19-2005, 12:48 AM
Re: power windows
If there is a prob with the horn its either the fuse is gone or the horn is shot.
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
