Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-15-2005, 09:04 AM
Sunbeam2 Sunbeam2 is offline
97 GC No Evaporator Drain Tube ???????
Help My carpet on the passenger side is soaked, I do not see any water dripping under the car with the ac running, where is the drain tube???
97 GC V-8 auto 4 x 4 Limited
Old 04-15-2005, 11:23 AM
Caribbean ZJ Caribbean ZJ is offline
Re: 97 GC No Evaporator Drain Tube ???????
No Drain Tube. Drains through the frame rail hole below the vehicle. My Jeep does the same thing. Pull passenger side carpet back. Drill a 1/4' hole in the center of the black evap housing. Wiggle a long wire through there then blow compressed air in the hole. This should unclogg it. Do a search on this, its a common jeep problem
Old 04-15-2005, 12:29 PM
Search where???
My haynes manual says that to remove the evaporator one of the steps is to disconnect the drain line, it you are to disconect it should it not be somewhere undert there?/
Where in the frame rail is the water supposed to drain out??
Old 04-15-2005, 03:00 PM
Use the search function here. Look under the vehicle around the passenger seat area u will see a hole, but u cant tackle the problem from there.
Old 04-17-2005, 09:43 AM
You gotta help me here I do l know what heading to search under on this forum, I keep getting a message that says my query is too short.
Where exactly do I do I drill this hole you mentioned and why must I wiggle a wire around in it?
At the bottom of the evaporator black case is a little plastic extrusion sticking down that appears to go thru the firewall but on the engine side it is behind the electrical box and is not reachable. It that the drain????
Old 07-24-2005, 10:07 AM
chuckster38 chuckster38 is offline
Re: Re: 97 GC No Evaporator Drain Tube ???????
I took the advice of drilling a small hole in the evaporator drain housing, accessed thru the passenger side firewall under the carpet at the bottom of the "V" inside the round circle, immediately received a large backflush of water, inserted a wire and blew some compressed air into it and plugged it. Works great now.
Old 08-01-2005, 07:12 PM
cbr92901 cbr92901 is offline
I had the same prob a couple weeks ago - water running into rear right passenger floor thru rear vent. I ended up removing glove compartment on the '95 JGC, cig lighter, and faux wood cover over the radio/controls. Then blew compressed air into both ends of the approx 1/2 " diam rubber hose located on left side of passenger compartment - it connects to evaporator. Blew air repeatedly into those hose ends, pulled down passenger side compartment carpet/pad to reveal bottom of evaporator where it enters firewall. There was already a 1/4" hole there, so I blew air into that (don't know if I blew that hole out or was already there). Anyway, all that blowin' worked. Then went to Home Depot and bought some PC-7 epoxy paste, mixed up a little from both ends of the tube, smeared it over the hole, and next morning hole was sealed up (the stuff hardened like plastic). No leaking since!
Old 08-01-2005, 07:21 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
if ou email me I can get you the instructions for unclogging the AC Drain
Joe
[email protected]
