Old 04-15-2005, 08:07 AM
mickkey3rd mickkey3rd is offline
EGR coincidence ?
Greetings folks
A burned valve in the number three exhaust port is the reason I had to do a rebuild on the mighty metro. Oh well such is life. Anywhooo I noticed that the EGR passages were completely clogged.
This got me to thinking, that the good folks who designed the engine
pick off exhaust from the #3 cylinder, and it seems that old #3 is the cause of many headaches. Coincidence?
Well, to be safe I retarded the timing just a bit. I think the designers use the EGR as more of a combustion cooler than emissions. I drive
all highway speeds, so the combustion temp, and EGR valve are both running full bore. Hmmmmmm
Check those EGR valves folks, or old #3 might suffer the same fate as mine.
Joe
Old 04-15-2005, 08:10 AM
Aaccck I meant to say advanced the timing!! Retarding would drive the exhaust temp up.
Joe
Old 04-15-2005, 07:33 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Re: EGR coincidence ?
hey thats no crazy statment mine did the same number 3 exh valve and cloged egr valve and ports crazy hu
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 04-16-2005, 01:16 AM
geozukigti geozukigti is offline
Common problem. Weird how it really only happens to the 92-94 3cyl's. I've not seem much problems with the 89-91's, or any of the 4 cylinders without EGR's.
Old 04-16-2005, 08:26 AM
yeah its a desin flaw i guess
Old 04-18-2005, 07:55 AM
Greetings folks
Yep, the mighty metro is a 92. Also I remember checking the plugs, they
were all running hot, white in color. I did not change the heat range like I should have. That might not even have helped, come to think of it.
Joe
