Mystery problem...
Ok, I recently purchased a 1989 blazer with the 4.3 motor TBI for $75 in pieces. put it all together, and it's in great shape, no rust, new mufler, etc... (former owner was a mechanic who was about to finish restoring it, but was involves in an accident and died :S )
My problem is the motor is running like crap... When you first start it it runs really rough and will not come close to idling without help using the gas pedal... It misses a lot and shakes like there's no tommorow. once it's been warmed up a bit it will idle, but roughly with the rpms going up and down and will stall after 10-20 seconds if not given gas. If I go for a short drive (I don't have it registered just yet so no long drives) it will not operate between 1/8 throtle and full throtle... if you just barely touch the gas pedal, it will slowly accelerate. If you floor it, it will hesitate for 1-2 seconds, then accelerate like it should. however, anything in between and there's no power. If you floor it a few times, this "dead" zone will be a little less noticible, though still there... Also after flooring it when you come to a stop it will for the most part idle just fine (even in gear), though there's a soft "poof" ever second or two, with the engline giving a soft shake when it happens. The check engine light does not come on at all... If I let the engine cool down, the problem gets worse again. Here's what I've tried doing to fix it... 1) checked all the spark plugs... all were the same color, almost white with a bit of a tan. 2) tested all the spark plug wires resistance, all were under the 30,000 ohms limit stated in my manual 3) with the engine running, and IAC valve disconnected (as it said in the manual) disconnected one at a time each spark plug wire and listened for a rpm drop... heard a small drop in rpm on all cilynders (and shocked myself 5-6 times :P ) 4) cleaned IAC vavle 5) cleaned and sealed with high temp silicone the EGR valve 6) checked the PCV (or PVC, can't remember what it's called, the one on the valve covers) valve, works fine 7)played with the timing, no effect one way or the other... 8)checked injectors, both giving a good spray (at idle anyway) Also, I have a vent hose which I cannot figure out where it goes... it is on the right side of the engine (left if you're looking from the front of the truck) on the intake manifold in between the throtle body and the valve cover, see http://www.clubplus.net/~tommy/blazer/TBI.JPG for a picture... (not my pic, found on web) When this vent house is left open, the motor idles high and shakes a LOT, when plugged, idle is low but engine doesn't shake near as much. I've looked all around within reach of the hose (which is about a foot and a half long) and can't find anywhere where it could go... I should also point out that this engine sat for 3-4 years... not sure if it effects anything... Anyone have any ideas? I really need to get this truck running as my current car is heading for the scrap heap soon... Also, my friend can get me a carburator for the engine to replace the TBI setup for $120 CND, would this solve the problem? and would it be worth it? Thanks a bunch, Thomas |
Re: Mystery problem...
i'm not sure where that goes but it probably has something to do with the front diff actuator. if you have any unplugged vacuum ports it will run like a bag of crap. there are many other things that might be causing your problems such as fuel pressure, incorrect timing sensors not working or not hooked up, exhaust restriction. the most important sensors are knock(side of block), tps(throttle position), and ect(engine coolant temp). since you got this thing as a pile of stuff you have no idea whats good and whats bad. with a good volt meter and manual you can check most of this stuff. does the check engine light come on?
Welcome to the forum. You may need to replace the fuel filter. It wouldn't hurt to flush the entire fuel system. If it sat for that long theres no telling what's in the tank, filter and lines. Good luck.
2003 Honda Element EX 2002 Kia Spectra (can't "Improve" or wife will kill me) 1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot) ![]() " Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White" http://www.myspace.com/officer_redneck |
And thanks for the welcome ![]() Quote:
Also, have tried 2 different tps's, and 3 different map sensors. I'll take a look at the ect and knock sensors in a bit... And being a brand new exaust system front to back, I would assume it's not exaust restriction. And like I said in my first post the service engine soon light does not come on at all...Thanks again... |
All the missing and shaking sounds like it could be a firing order or valve timing (or sticking) issue, maybe. The one at a time plug wire removal should have ruled out incorrect order, plus that doesn't sound like a mistake you'd make based on how well you described the issue and what you've done so far. Just shooting in the dark here, but I'd want to check the valve operation. I'm not sure if they're still the preferred method, but my dad used to have a vacuum gage that was marked to tell you if valve timing was off, and of course erratic movement of the needle would indicate a mechanical issue like sticking or other causes for poor compression which would then lead to a cylinder by cylinder compression check. Best of luck.
1.) Cap and Rotor?
2.) Did you disconnect the timing wire when setting the timing to zero?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: Mystery problem...
2) yes I disconnected the wire (and reconnected afterwards) Aside from that, I've checked the resistance of the ect sensor, it read 3,000 ohms at roughly 15 celcius. not sure what it should be, but given the manual saying 100,000 ohms at -40 and 70 ohms at somthing like 90 celcuis (not sure of the temp, don't have it beside me) 3000 doesn't seem absurd I've also checked the tps, and it's working perfectly (0.5 volts at closed throttle going to near 5 volts at full throttle) As for the knock sensors, can you show me in a picture of some kind where they are? the manual doesn't mention them and I've no idea where they are... Fuel filter also had no change... Just for the hell of it I also checked the firring order, no problem there. Allbert, can you go into more detail on how one would check valve operation... I actually know less about car engines then one would assume :P (I know dirt bike mechanics inside and out, which has helped me, but cars are quite different) Thanks again!
I would check all your vacuum hoses for leaks.
The IAC is probably trying hard to compensate for a vacuum leak somewhere in the system.
B) would it run worse when cold then warm with a vacuum leak? because once mine is wamred up it idles (though still like a POS) |
That would be your vacuum leak for sure.
Can you take some clearer shots of it, I can't really see it.
http://www.clubplus.net/~tommy/blazer/mytbi.jpg
the yellow hose on the right is just a short piece of hose that is blocked off that I use to cover the opening where the air filer plugs onto, the other yellow hose is to repair a broken plastic vent hose... The hose that I don't know about is the one going up and resting on the air filter screw thing... It's been blocked this whole time... (it runs even crappier when unplugged) |
Check you EGR valve and see if it should be inserted on it.
Thomas |
PCV valve hose?
