cruise stopped working and then a few weeks later some guy let me know that my brake lights were out. Checked the fuses - not the problem. Someone said it may be a switch, huh? Has anyone else had this problem and any ideas on how what's wrong. Thanks!
Re: cruise and brake lights quit working
Probably the brake light switch at the pedal. Look under the dash just below the brake pedal pivot point and make sure the connector is still on the switch. If you know how, check the switch with a volt/ohmmeter.
The cruise control is deactivated when the brake pedal is pushed. The brake lights activate when the brake pedal is pushed. I'm not sure on the Montanas, but many cars use the same switch to communicate to both the cruise and the brake lights. On other cars, the cruise won't work if the brake lights are not working. I seem to recall that the brake light assembly on Montanas have had some issues where the circuit board either melts or has problems. Other posters may have more specifics....good luck...Glen |
Re: Re: cruise and brake lights quit working
Thanks, I'll try to check that out.
lights
Just have to ask, did you check the bulbs? If the brake bulbs are burned out this will affect the cruise control.
Re: lights
Light bulbs
I would guess that the engineers wired the cruise control and brake lights together so that a person would be alerted to the fact that their brake light bulb is burned out. Now, if you don't know this and they don't tell you, it can cause headaches for the owner trying to figure out what's the problem could be.
Could it be the same engineers who designed this wonderful leaky manifold gasket?
Engineers
Don't for get the easy to replace back 3 sparkplugs or air filter!!
I would take 3 back plugs over intake mainfold gasket anyday !!!!!
Re: Engineers
Two clips, hose clamp and a couple of electrical connectors! I ripped my flexilble rubber hose trying to get it loose! Why go through that hassle when they could have designed a slot in the top edge to remove the edge and slide another filter in? As far as other minivans with spark plugs replacement being difficult, that's the point! Why have the cowl/inside dash extend so far forward? I would be willing to give up five inches of dash/windshield to be able to see what the backside of the engine looks like.
Stuff it in and don't worry, we won't have to work on these vehicles. This seems to be the attitude of today's design engineers!! |
Re: lights
Thanks. I checked the fuses and lights first. I have checked the switches under the brake pedal and they "look" ok to me. Don't have a clue now. Guess I'll have to take it to the dealer$$$$. Appreciate your comments.
Switches
I don't know how you can "look" at the switches by the brake pedal and tell if they are "ok". You should use a meter to see if they are working or not.
Let us know what the dealer finds out so the rest of can learn the reason for the failure. Good Luck. |
Re: Switches
I couldn't get the connectors unplugged and didn't have time. I will let you know what was wrong. Thanks for steering me in the right direction.
Re: Light bulbs
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
