Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-14-2005, 10:19 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
Del Sol Si, Z6 problem..
at first i thought it was limp mode, because at it feels like it stops the spark at 3k in first gear, but the more i drove it and tried different things i'm not sure what it is now.. alright, if i am running 1/4 throttle the car runs fine, idles and starts fine, no CEL..no code, i changed the fuel filter, i tried adjusting the timing, new plugs/wires/cap/rotor but the car still will just lose all power when i'm over 1/4 throttle under load. it revs fine up to redline but as soon as it's under load, anythign over 1/4 throttle just dies, i can cruise just fine down the road at 1/4 throttle all the way to 5th so it runs and drives still.. any thoughts/ideas as to what to try next?
it's a 94 del sol si.. all stock absolutely no mods.
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 04-14-2005, 10:25 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Del Sol Si, Z6 problem..
check to see how strong the spark is ? check timnig ? also is it running really rich when you give it more than a 1/4 throttle
Team Lonely Drivers
Old 04-14-2005, 11:18 PM
i adjusted the timing, changed the cap/rotor/plugs/wires and the spark is good when i crank it to check for spark.. it's odd that the car fires right up no problem, idles high when cold, idles down when it warms up.. runs normally at under 1/4 throttle
could a bad TPS do that?
i'm not sure if it's running rich or not, when i hold it to the floor in first once it hits 3k it starts slowing down, like the ignition was turned off.. then when i let off the gas it backfires once and runs normally.. i'm thinking it's still spraying gas but cutting the spark when i try and accelerate quickly
-Josh
projects:
Old 04-14-2005, 11:31 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
voltage test the TPS and MAP.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
