Old 04-14-2005, 10:02 PM
OZBIRN454 OZBIRN454 is offline
Send a message via MSN to OZBIRN454
97 4.3 converter broken 02 code
Hi All I just got this 97 dumped on me and was told it had an 02 code so all 02 sensors were replaced I also noticed that the converter is broken up I can here it ideling and when I shake it. Is there any common problems for this year? He said that the gas mil went to hell also. I drove it home and seems to drive fine. I just don't want to put a converter on and burn it up.
Old 04-15-2005, 12:45 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 4.3 converter broken 02 code
1.) Replace the ignition switch.
2.) Replace the Cat.
3.) Do a complete tuneup including:
Cap & Rotor
PCV Valve
Wires
Air Filter
AC Delco Platinum Plugs
Fuel Filter
Flush and refill all your fluids.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-15-2005, 04:41 PM
Re: Re: 97 4.3 converter broken 02 code
Cap & Rotor
PCV Valve
Wires
Air Filter
Fuel Filter
Thanks Everything was done 3 months ago except the converter. Why would it go bad I always thought raw fuel would do this but wouldn't it send a code? thanks Oz
Old 04-15-2005, 09:38 PM
BlazerLT's Avatar
AF -Advisor
So you are telling me everything in that list is done?
Or are you assuming everything was done?
Old 04-16-2005, 06:00 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
It was probably going bad prior to 3 mos ago... Cats don't just break up instantly.. Takes a while... Replace the Cat and you'll be fine.
Old 04-16-2005, 12:38 PM
No everything was done at dealer.
