Old 04-14-2005, 09:11 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Brake sound
I changed the front pads in July last year and it might be time for them to be changed again since they were only 10 bucks. But i was searching and i found a thing about wheel bearings. It did not say exactly the noise i had so i figure i ask. When i am in park and i go to drive or reverse it does not matter and i have the foot on the brake pedal and goto steer to get out it makes this god awful sound like a caliper would be stuck but i do not have any problems driving with it if it would be stuck. It is not a clunk but more like arhhh sound like something crunching, its hard to explain. The pads are starting to squeal real bad so i cleaned them up after draining the oil and putting it back in the engine trying to solve oil leak. I am gonna jack it up saturday and see if the pads are getting bad and if the rotors are glazed or warped.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 04-15-2005, 12:42 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Brake sound
Check your transfer case and differential fluids.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-15-2005, 02:04 PM
Re: Brake sound
okay will do saturday
Old 04-16-2005, 09:33 PM
Re: Brake sound
Transfer case fluid good and front and rear differential fluid good. They look to be where they need to be just discolored i guess from age. I might do the transfer case on sunday since it has both plugs there the other two i wont touch.
Old 04-16-2005, 11:32 PM
BlazerLT's Avatar
AF -Advisor
Re: Brake sound
Check caliper pins for play and wear.
Grease your front end.
10-11 grease fittings.
Old 04-17-2005, 10:39 AM
Re: Brake sound
I will check the pins.
The front end was greased at the end of February right after inspection.
Old 04-17-2005, 11:19 AM
BlazerLT's Avatar
AF -Advisor
Re: Brake sound
Did you grease it?
Did you make sure all 10-11 fittings were greased?
Old 04-17-2005, 11:58 AM
Re: Brake sound
I did not grease it because thats something i do not have patience to do.
I took those pics a few minutes ago. The rotors look good the pads are iffy only about 1/4" left. There is yellow liquidy grease type stuff at the end of the cv boot like it would be oozing from there and a little on the side of the shock absorber and some back a little. Could that be the problem right there?>
