Old 04-14-2005, 05:10 PM
davidj0 davidj0 is offline
belt chirping and a dragging noise '01 Taurus
I installed a new belt in my '01 Taurus last week and was okay till yesterday, then it started to chirp and it seems like an intermitting dragging noise also. I gave a quick spray of WD-40 but it made no difference. Anyone have any idea what it could be.
Old 04-14-2005, 10:33 PM
Wodinator Wodinator is offline
Re: belt chirping and a dragging noise '01 Taurus
perhaps it needs to be tightened.
Old 04-15-2005, 02:45 AM
maspoon maspoon is offline
sure its the belt? maby the alternator.
I never heard of using wd40 on belts. should that be done?
let us know what you find out
Old 04-15-2005, 07:06 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
check the idler and tensioner pulleys. There are small bearings inside that go bad quite often.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-15-2005, 12:53 PM
Willyum Willyum is offline
Oil and belts do not mix! If you have to use soap.
Old 04-15-2005, 07:03 PM
I use belt dressing... its not oily but kinda sticky.. if you use this take the belt off and spray it on let it soak then wipe off any excess. it gets every where if you spray it on and leave a lot on the belt
Old 04-16-2005, 03:15 PM
KimMG KimMG is offline
AF - Advisor
oils can cause deterioration of rubber parts. Using WD-40 can cause the belt to slip and make noise. Use nothing or belt dressing on fan belts. Dressing is real sticky and helps the belt grip the pulleys.
Old 04-17-2005, 07:13 AM
hughw hughw is offline
Listen closely to see if the chirping is coming from the belt....a common problem is the Cam Sensor that chirps like you are discribing....it is located on top of the engine on the opposite end from the belt.
Old 04-17-2005, 07:58 AM
denisb denisb is offline
If it ony seems to drag at times, it could be related to your AC. listen to see if you hear your AC clutch kick in before it starts dragging. This would tell you if your problem lies within your AC problem, if so, you might have a bad AC compressor.
Denis
Old 04-17-2005, 06:16 PM
thanks, it's fixed?
I tried belt dressing and it has stopped. Thanks to all for your advice.
