| COMPLETELY off-topic Talk about anything other than cars. But you can't be mad and angry in this forum! |
For Sale: New 19' LCD Monitor
Hi,
I dont really post much in the this area of AF, but it thought i should give a heads up on anyone who is looking for a good lcd monitor. I have a brand new, unopened, Dell 19' Flat Panel LCD Monitor that I want to sell. I already have one of them, bought this extra one thinking i could use for a pos pc i have, but I ended up not using it. Its truly a great monitor, and im not just saying that because i want to sell it. The monitor sell for $529 new, i am trying to get about $429 out of it. I also have a $25 coupon from dell for any purchase over $150 that i will throw in too. Please e-mail me if you are interested. I am more than willing to send more pics if needed. Picture: Dell 19' Flat Panel LCD Here is a little description of the monitor: The Dell™ UltraSharp™ 1905FP Flat Panel Monitor redefines the performance of LCD displays with a stylish new Dell industrial design, advanced functionality and the best in LCD panel technology. Whether for corporate or home use, the UltraSharp 1905FP maximizes the viewing experience with a thin bezel and panel that swivels, tilts and pivots to satisfy the most demanding of users. Simple yet efficient on-screen controls enable the users to customize to their needs. It utilizes an Active Matrix TFT LCD that displays sharp and brilliant images of text and graphics with a maximum resolution up to 1280x1024 pixels. Fast 20 ms response time delivers excellent image quality in high motion applications reducing ghosting, jagged edges enabling crisp, clear images. With 800:1 contrast ratio for high color accuracy and uniformity, this monitor is ideal for usage in a variety of environments from trading floors to graphic design and healthcare. Wider base provides stability, while the integrated rubber sleeve provides a clean cable management solution. With four USB 2.0 ports, two located on the side of the display, the 1905FP enhances your visual experience. Specs: Diagonal Size: 19" Viewable Size: 19" Display Type: Flat panel display/TFT active matrix - desktop Depth: 8.425" Features: Panel pivot, 4 USB 2.0 ports, Height adjustable stand, Integrated rubber sleeve Height: 22.97" (fully extended in portrait mode), 16.40" (compressed in landscape mode) Weight: 15.25 lbs Width: 16.35" Image Max H-View Angle: Typical ± 85° Image Max V-View Angle: Typical ± 85° Analog Video Format: RGB Compliant Standards: 100 mm VESA® Connectivity Technology: Cable Device Type: Flat Panel Monitor with Height Adjustable Stand Dimensions (WxDxH): 16.35" x 8.425" x (16.40" - 22.97") Dimensions (WxDxH) / Weight: 16.35" x 8.425" x (16.40" - 22.97") / 15.25 lbs Dot Pitch: 0.294 mm Enclosure Color: Midnight Gray Environmental Parameters: Temperature:- Operating: 41°F to 95°F, Storage: -4°F to 140°F; Humidity:- Operating: 10% to 80% (non-condensing), Storage: 5% to 90% (non-condensing); Altitude:- Operating: Up to 12,000 ft, Non-operating: Up to 40,000 ft; Thermal dissipation: 221.937 BTU/hour (maximum), 109.261 BTU/hour (typical) Factory Preset Resolution Modes: 720x400 pixels @ 70.1 Hz, 640x480 pixels @ 59.9 Hz, 640x480 pixels @ 75 Hz, 800x600 pixels @ 60.3 Hz, 800x600 pixels @ 75 Hz, 1024x768 pixels @ 60 Hz, 1024x768 pixels @ 75 Hz, 1152x864 pixels @ 75 Hz, 1280x1024 pixels @ 60 Hz, 1280x1024 pixels @ 75 Hz Image Brightness: 250 nits (typical) Image Contrast Ratio: 800:1 Lamp Type: CCFL (4) edgelight system Max Operating Temperature: 95°F Max Resolution: 1280x1024 Pixels Max Sync Rate (V x H): 75 Hz x 80 KHz Min Operating Temperature: 41°F Port(s) Total ( Free ) / Connector Type: 15-pin D-subminiature (blue) / DVI-D (white) / 4 x USB 2.0 Power: 90 to 264 VAC / 50 or 60 Hz ± 3 Hz / 1.5 A (Max.) Humidity Range Operating: 10% to 80% (non-condensing) Diagonal Size / Viewable Size: 19" / 19" Compatibility: PC
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires 96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge Hala Madrid! |
