Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 04-04-2002, 02:18 AM
JKdonger's Avatar
JKdonger JKdonger is offline
time to go low
Ok I guess I'm giving in, even though I said I would never lower my car, I will be lowering it this weekend. It just looks way better lowered, I will be using the GR-2 struts and HKS springs combo. Anyhow, any advice on the install process and am I suppose to cut some bump stops or something like that?
Old 04-04-2002, 12:49 PM
donsster donsster is offline
Send a message via AIM to donsster
You might want to seriously consider KYB AGX shocks instead of the GR2s. The GR2s are a stock-type shock which will probably fail quickly with aftermarket springs.If the GR2s don't fail your car should have a much worse ride and handling than stock because the shocks weren't designed for the extra force the HKS springs will put on them.
Unfortunately there is not a really cheap way to drop a G20 and keep it's good handling and ride
Don
Old 04-08-2002, 12:47 PM
kenchan's Avatar
kenchan kenchan is offline
donno about the GR2 thing, but i would recommend raising both ends when you do the front put the car on jack stands too. the stabilizer bar gets into the way when you only lift one side.
otherwise the install is a breeeeeeeeeeeeeeeeeeeeeeeeeeeeze.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 04-09-2002, 04:29 AM
JKdonger's Avatar
Correct me if I am wrong:
I read and have been told by many that the KYB AGX's give a pretty stiff ride even on the sofest setting, my goal here is to keep my ride quality as close to stock comfort level as possible. The GR2's struts are a little stiffer than the stock struts; I believe that if I use these struts in conjunction with the HKS lowering springs it will yield me the best combo for what I am persuing. I will cut about an inch off the bumpstops and I hope it will give the GR2's enough travel. I will post before and after pics when I am done. Thanks for the advise y'all
