Old 04-04-2002, 01:59 AM
-=BOOMER=-'s Avatar
-=BOOMER=- -=BOOMER=- is offline
Send a message via ICQ to -=BOOMER=- Send a message via AIM to -=BOOMER=- Send a message via MSN to -=BOOMER=- Send a message via Yahoo to -=BOOMER=-
Rear disc conversion.
So i got my rear disc brake conversion today.
Now all i need is the time to install it.
Old 04-04-2002, 08:50 AM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
Where'd you find a donor vehicle. I've been checking junkyards around here for a year with no luck!!!
98 Civic LX - Bottle-Fed
Old 04-04-2002, 09:34 AM
shocky shocky is offline
Send a message via ICQ to shocky Send a message via MSN to shocky
Lightbulb
Could you send me a link or maybe your own installation experience of a rear disk brake conversion with pictures please. I have everything except I don't know how to install them
Your car it's Civic Ex Coupe? MINE IS
94 Acura Integra 4 Door, JDM Si-R II B16A 5.4Million Series Engine Swap (170HP Stock), With CTR Camshafts, STR Camgears, Clutch Masters Stage 4, DC Sport Ceramic Header 4-2-1, Exhaust System 2.25" W/Apex-i N1 Cat-Back, AEM Cold Air Intake, ECU Erick Racing 5,800rpm Vtec, B&M Fuel Pressure Regulator, Y21 Code GearBox, 16" Rims W/Yokohama Avs Sports. It's not much but I still can smoke fools. Oh Yeah and Don't forget, I'm Proud Member of Guatemala Streetracing. http://www.gtstreetracing.com
Old 04-04-2002, 12:48 PM
JayFidizzy's Avatar
JayFidizzy JayFidizzy is offline
Banned
Send a message via AIM to JayFidizzy
http://www.hazone.com
Go to the how to section on the right hand side of the page and click on Rear Disc Swap
Old 04-04-2002, 01:40 PM
-=BOOMER=-'s Avatar
I got this off Ebay, 250$.
I dont have a dingital camera to document instalation but i will see if i can borrow one.
Oh here is another link for info on geting these installed.
http://www.hybrid.honda-perf.org/tech/brakeswap.html
(its not my link i stole it from Rice-Rocketeer on another thread.)
Here is a question to those in the know, is the master cylinder/proportioning valve on my 95 EX going to be big enough or will i have some problems with pedal travel and squishyness? should I start looking for GSR parts? I have heard that the one on the EX is biger then lower models and may not need to be swaped out.
Old 04-04-2002, 01:54 PM
THANK YOU ALL YOU GUYS FOR YOUR HELP! THANKS :frog:
Old 04-05-2002, 12:25 AM
Rice-Rocketeer Rice-Rocketeer is offline
The master cylinder shouldn't need to be swapped out in any case as long as your not doing a 4 piston caliper upgrade or something similar. The proportioning valve is the valve that dictates how much to bias the hydraulic pressure from the front to the back and this will need to be replaced with the one from the donor vehicle or similar. If not the rears won't get enough pressure to be effective and you'll have to mash the pedal to the floor to get good braking.
Lookin at my gucci, it's about that time...
Rear Disc Conversion luti Engineering/ Technical 0 10-27-2002 01:56 PM
Rear disc conversion on a 96 hatch whttrshpunk Tires and Wheels 3 10-14-2002 01:42 PM
Eg Civic Rear Disc Conversion... t0p_sh0tta '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 06-04-2002 07:19 AM
Rear Disc conversion from Integras Ebranste '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 03-22-2002 03:32 PM
