Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 04-14-2005, 02:05 PM
flrydr flrydr is offline
73 BEETLE STALLING at stops
New to this forum.and to beetles just hepling a friend I hope you can help, the beetle has been stalling at stops. starts right up seems to be running rich also, new plugs, distributor cap, oil change, was stalling before all that work done...question is there a fuel filter on these cars and where is it???
thanks in advance
Old 04-14-2005, 04:35 PM
boschmann boschmann is offline
Re: 73 BEETLE STALLING at stops
The fuel filter is normally in the fuel line between the fuel pump & carburetor. Sometimes people will put them in line between the frame rail & front of the engine or between the fuel tank & frame rail. The problem sounds more like a carb adjustment issue.
Old 04-14-2005, 05:22 PM
Re: Re: 73 BEETLE STALLING at stops
Yea I was thinking the same thing but I wanted to cover all bases just in case it was something simple like a clogged filter. But I will take a look at the fuel mixture.
Old 04-15-2005, 02:28 PM
BoatCop's Avatar
BoatCop BoatCop is offline
Also check the choke circuit. If it starts right up when cold but stalls when warm and running rich, the choke wire could be disconnected/broken/hooked up wrong, or the choke oout of adjustment.
Alan
BoatCop
Old 04-27-2005, 09:50 PM
bgarage bgarage is offline
thanks in advance
Hi sounds like you need to remove the idle jet that is on the side of the carb { the same side the choke element is on} and take air and blow out the jet. you will notice when you remove it from the carb that the tip will be stopped up causing all your problems.
