Put a 2" lift now i have a problem
I had a 2 inch lift put on (Blocks and spacers) and now i get a vibration at 25 to 35 mph it will smooth out at higher speeds it feels like your driving on divits on the road i looked at my tire tread because i first thought that they were somehow uneven but no such luck, i didn't have this problem before the lift and im not sure what else to do HELP
Re: Put a 2" lift now i have a problem
Well a 2" lift shouldn't cause this, but you may check to see if it is the drivelines. Pull the front one out and see if that takes care of the vibration. You may just have some worn U-Joints that are now showing thier age because of the increased angle.
Steve '98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s. |
I agree with Steve,2 inches should not cause a problem but it could be your driveshaft angle.I saw it on an xj with only 2 1/2 inches of lift.If everything else checks out,you might want to think about a t-case drop.All you really do is put some spacers between the trans crossmember and the bottom of the jeep and it can give you a better angle.
Check the wheel alignment too.
Re: Re: Put a 2
Re: Re: Re: Put a 2
wheel balance
check your wheel balance I put on a 3 inch lift and had a wicked shimmy at about 50, had the tires balanced problem solved.
Re: wheel balance
On each end of the front drive line are 10mm hex bolts, take all four off of each yoke, then the drive line will come right out. Carefull you don't let the U-joint caps fall off the joints.
Re: Re: Put a 2
Hey Mints - long time!
When I put the two inch lift on my 96, I went ahead and put a 1" spacer under my transfer case just in case. I got the plans for how to build off the aussie go.jeep-xj site. Immediately got it aligned, haven't had a problem at all...
You like jazz, she likes Klingon opera, so you compromise - you listen to Klingon opera...You like Cherokees, she likes Grand Cherokees, so you compromise - you buy a Grand Cherokee... |
Re: Re: Put a 2
Ill try that i hope it solves the problem, i was going to replace all the u joints to see if that fixed it maybe i will do that anyway... ill let you know what happens
Re: Re: Put a 2
Re: Re: Put a 2
