Old 04-14-2005, 01:43 PM
lie495s14Q lie495s14Q is offline
How much W/rms do i getting? [noob question]
did the search but came up nothing. so here i go.
my ride is a 95 240sx with the OEM clairian amp and cd reciver. i upgraded head unit to a sony3300 which out put 52x4 hooked up to the OEM clairian amp with an wiring adapter. now i have 2 pairs of infinity kapaa speakers that recommand work best at 75w. how much watts or rms am i getting ?
Old 04-14-2005, 02:30 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: How much W/rms do i getting? [noob question]
well the sony deck would be giving it 26rms or 52 max. You have to tells us how much the amp puts out and just add it up, if its to much turn down your amp a bit so u dont blow your speaks
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-14-2005, 03:20 PM
it's an facotry OEM amp that comes with the car. the oem speakers are rated at 40w each from the spec at bottom of them. does that mean oem amp puts out 160w/rms total ? the tech guy from cruntchfield.com told me that my oem speakers were working at 2oms. any idea ? guys ? thank you.
Old 04-14-2005, 04:03 PM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
what kind of car runs 2ohm speakers? Ive found 8 ohm and even the discusting 10ohm but i think 2ohm stock would make hte head unit catch fire, unless you have one of those lame "premium systems" with daisy chained speakers.
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
Old 04-14-2005, 09:25 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: How much W/rms do i getting? [noob question]
he said it has an OEM amp, so the headunit doesn't have to do anything.
To answer your question, if your car has an OEM amp seperate from the headunit, then unless you rewired all of the speakers they're getting the exact same amount of power as they were before, which is the same amount of power that the stock speakers were getting.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-14-2005, 10:09 PM
thank you Mr. sr20det. that answers my question. do you know where i can find the wiring diagram for my factory amp? i don't wanna re-run the speaker wires to the front. so much hassel.
Old 04-15-2005, 07:44 PM
http://files.automotiveforums.com/ga...cat=500&page=1
here is da pic. Does it mean my new infinity speakers are running at 2ohm, 40watts ?
Old 04-15-2005, 07:49 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
No, never look at the max wattage. The "Nominal" or RMS wattage is what is useful in determining the actual power output of the speakers. So yours are running at 20 Watts.
Old 04-16-2005, 09:30 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
hell..i never even look at the RMS ratings on speakers. i can't remember when the last time i looked for it
I love them sub wufers
Old 04-18-2005, 10:31 PM
i have no sub, only 4 infinity speakers. when i set bass at max. the highs tend to fade out when the bass hits. if i lower the bass, it's fine. should i add a sub+D-amp? or upgrade to a 4-channals amp to power the speakers?
Old 04-19-2005, 03:30 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
if you want more bas while maitaing you high and mids then you shoudl get a sub. then use your regular speakers to do the mid and high work. a crossover would help in this endeavor.
Old 04-19-2005, 05:41 PM
simply and a good idea. i think i'll do that. thanx for replay.
Old 04-19-2005, 08:09 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
dont you know how to match speakers iwth power...
you take the speakers Peak and put an amp with that number as its RMS....duh...other wise you will blow the speaker fomr underpowering it....
Old 04-19-2005, 08:41 PM
Re: Re: Re: How much W/rms do i getting? [noob question]
blow a speaker from underpowering it?
Old 04-19-2005, 09:43 PM
GSteg's Avatar
i'm smart with the volume knob. it's common sense to turn down the volume when you hear something funny. i buy the biggest amp possible and just under use it
my horns gets very annoying after about 5w. it'll get too loud for my taste after that.
