Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-14-2005, 11:31 AM
pahrumprams pahrumprams is offline
85 grand marquis stalls and wont start after about 10 miles
I have a 1985 Grand Marquis that starts perfectly in the morning but after about 10 miles of driving it will stall. It doesn't matter if I am at a stop or moving. It feels and sounds like it's out of gas. After it stalls it will not start for anywhere from 10 minutes to an hour or more. I replaced the ignition module (distributor mounted) and the voltage regulator on the advise of a self proclaimed "expert" but I still have the same problem.
Any suggestions would be greatly appreciated.
Old 04-18-2005, 08:50 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 85 grand marquis stalls and wont start after about 10 miles
This is the 5.0 Liter engine, right? Sounds like the symptoms of a bad "Hall Effect Sensor". There are many posts about it, both here and in (I think) the Mustang forurm.
Basically, there's a sensor in your distributor that tells the coil when to fire, and when it goes bad it works erratically as you've described. Time for a replacement.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 11-12-2005, 10:20 AM
marinecapshop marinecapshop is offline
just wanted to know fixed your problem yet? i have same problem my 85 only has 90 k on it i have been everywhere and no one seems to know what to do. If anyone else knows of this stalling problems help help help please i hate to get rid of this neat old car
Old 11-12-2005, 06:01 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: Re: 85 grand marquis stalls and wont start after about 10 miles
Try fredjacksonsan advice.
Old 08-23-2006, 05:44 PM
glasser3 glasser3 is offline
Send a message via AIM to glasser3 Send a message via MSN to glasser3 Send a message via Yahoo to glasser3
ive got the same problem with my 87 does anyone know how to fix it i hate it because i cant even trust my car to get me down my driveway anymore and i dont wanna replace it i love my big ol' boat
Old 08-23-2006, 09:31 PM
2OOOLS 2OOOLS is offline
Send a message via ICQ to 2OOOLS
when I was driving a cab one day my car kept stalling at every stop I made. turned out it was a dirty fuel filter.
Old 08-23-2006, 09:35 PM
hmm might have to try that
Old 08-26-2006, 01:18 AM
okay i changed the fuel filter on my car today and it still didnt solve the problem for me, i also tried changing the plugs that didnt help either
Old 09-14-2006, 07:07 AM
Marco Sr. Marco Sr. is offline
Send a message via ICQ to Marco Sr.
Ok the one thing most people overlook (myself included) is the pickup coil in the distributor that little (bleep bleep) cost me over 300 dollars in other repairs before I replaced it (a 25 dollar part) of course I did have to take the distributor out and to the shop and have the gear pressed off (in 26 years of working on cars this was the only one that I have encountered the drive gear for the distributor pressed on) all others I would just remove the rollpin and start twisting it till it finally cleaned off enough to remove.
It was causing my 86 GM to just shut off and it would take anywhere from 15 - 30 minutes or longer if it was a 90+ deg. day before it would restart.
Marco
Old 09-16-2006, 02:12 PM
rhandwor rhandwor is offline
Wiggle the wires to the distributor does this effect the motor. I had a 5.0 liter t-bird and I had to replace the wires. I would try a rebuilt distributor with new electrical parts. Turn the motor until the rotor comes to a mark in the side of the distributor mark it with white out. Then pull the distributor buy a rebuilt one and remark the new unit. This saves time it will turn a little so you can get it in then set the mark. Be very careful or you will have to retime the engine. A single plug by the dist has to be unplugged to do this.
You can't install the part without a puller. I have found a loose ground wire for the computer, this can cause problems.Pull the pass side cover by where your right foot would go the computer and ground are very close. EEc relay should also be close with fuel tank relay in the trunk by the pass side hinge.
